about the 1.10 version
I downloaded version 1.10 and she does not want to install properly. Someone has a solution? Thanks in advance.
atc98092 wrote:Can you be more specific about what isn't working? What operating system (Mac, Windows, Linux)?
atc98092 wrote:OK, let's try a slightly different install method. Right-click on the install file and select "Run as Administrator". Accept the warning message that appears, and then see if Serviio installs correctly.
I've never had to do it this way, but if you're encountering permissions issues when installing this might resolve it.
atc98092 wrote:Now we need to see your log, to see if there's an error reported. If Serviio truly can't start, the log should tell us why. You can find the log in C:\Program Files\Serviio\Log. We don't need the Derby log, just the Serviio log.
atc98092 wrote:You should be able to zip/rar the file quite small. I would be shocked if you couldn't attach a normal zipped log. What is the size before and after compressing the file?
atc98092 wrote:I can't open it on this computer, but I can from home tonight. We'll see what it has to say, unless someone else looks at it first.
2018-01-04 19:03:54,294 WARN [MultiCastUtils] Host IP address 192.168.1.28 is not available, will try again 9 times
2018-01-04 19:04:40,608 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2018-01-04 19:05:27,566 INFO [Device] Updated bound IP address of Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 127.0.0.1
atc98092 wrote:All right, have it open. It is incomplete, as it doesn't contain the initial startup of the server. However, there is something that I think might point into the correct direction. It appears that for some reason Serviio is attempting to use an IP address that isn't available. The first error is:2018-01-04 19:03:54,294 WARN [MultiCastUtils] Host IP address 192.168.1.28 is not available, will try again 9 times
It then counts down the 9 attempts. After that, it returns this:2018-01-04 19:04:40,608 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
That one also counts down the 9 attempts. The final message:2018-01-04 19:05:27,566 INFO [Device] Updated bound IP address of Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 127.0.0.1
So, Serviio is running fine, but can't seem to find a usable network connection on your computer. So, you should be able to connect to the console from the Serviio computer using this URL: http://localhost:23423/console. Once you can get into the console, you can go to the bottom of the Status page and see what it shows in the Network Settings box. It is a dropdown box if you click it, and it will show all discovered network connections on the computer. There is also an Auto Detect setting. See if you can find the correct network card for your home network.
If you can't get into the console, then I'm at a loss on how to help. By the way, does your computer have more than one network card? Say both a wired and wireless card? Just trying to figure out why it can't find a network connection to use.
atc98092 wrote:Sorry, http://localhost:23423/console is what you type into a web browser to access the Serviio console. This particular address will only work on the Serviio computer itself. Until you can get Serviio talking to the correct network card, you won't be able to access the console from any other computer on your network.
atc98092 wrote:Yes, ZIp has past installs still available. There's no way to browse for them. You have to edit the download URL with the version you desire. For example, the current download link is http://download.serviio.org/releases/se ... -setup.exe. Change the 1.10 to the version you want. The previous version would be 1.9.2.
Users browsing this forum: No registered users and 60 guests
