Toshiba 43LF621U19
chas638
Post Sun Dec 02, 2018 5:14 am
Toshiba 43LF621U19
Help
I just bought this Toshiba 43LF621U19 TV. How do I setup to stream from my computer to this FireTV? It works great with my Samsung BluRay player but would like to stream directly to the new TV.
Thank you
Chas
Post Sun Dec 02, 2018 5:43 pm
Re: Toshiba 43LF621U19
OK, this TV runs the Amazon Fire TV OS, similar to some brands having Roku TV. So, what you need is a DLNA player for the Fire TV OS. I believe Kodi is available, as is Vimu. Apparently you have to side-load Kodi, although it's the one I would recommend most. It's what I use on my Shield. Vimu is available from the app store, and the screenshot on the Vimu home page even shows a Serviio icon. https://www.vimu.tv/ It's probably your best option, unless you are comfortable side-loading Kodi.
Return to Toshiba
