Freebsd 11.2 problem status and stop serviio
Plohish
Post Fri Dec 07, 2018 10:40 am
good day!
I put serviio on my freebsd 11.2 server
serviio starts perfectly and works well, but if you check the status of the process /usr/local/etc/rc.d/serviio status - the system says "serviio is not running."
And worst of all, I can't stop serviio with the /usr/local/etc/rc.d/serviio stop command
this does not work.
Post Fri Dec 07, 2018 3:16 pm
Re: Freebsd 11.2 problem status and stop serviio
Can you attach a copy of your Serviio log here, so we can determine if it is actually running, or if there's some sort of error shown? When you say it works well, I'm assuming that Serviio must be visible on your network and streaming media as expected. I just created a fresh install of Linux Mint 18, so I can test there to see if it exhibits the same issues that you mention on your install.
Plohish
Post Fri Dec 07, 2018 3:34 pm
Thank you for your help.
Today I solved the problem "impossible to stop the service"
I looked at the log file and found that the system could not correctly determine the host name
2018-12-05 22:03:12,554 ERROR [ApplicationInstanceManager] shluz.plohish67.ru.1.16.172.in-addr.arpa: shluz.plohish67.ru.1.16.172.in-addr.arpa: hostname nor servname provided, or not known
java.net.UnknownHostException: shluz.plohish67.ru.1.16.172.in-addr.arpa: shluz.plohish67.ru.1.16.172.in-addr.arpa: hostname nor servname provided, or not known
   at java.net.InetAddress.getLocalHost(InetAddress.java:1505)
   at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:68)
   at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:301)
   at org.serviio.MediaServer.main(MediaServer.java:118)
Caused by: java.net.UnknownHostException: shluz.plohish67.ru.1.16.172.in-addr.arpa: hostname nor servname provided, or not known
   at java.net.Inet4AddressImpl.lookupAllHostAddr(Native Method)
   at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:928)
   at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1323)
   at java.net.InetAddress.getLocalHost(InetAddress.java:1500)
   ... 3 more
I added the host name to the host file, then the "/usr/local/etc/rc.d/serviio stop" command correctly stops serviio!
however, the command of "/usr/local/etc/rc.d/serviio status" cannot find a working system and writes "serviio is not running"
while the log file does not get anything ...
while my network detects a media server and devices can perfectly play content
sorry my english, i use google translator :)
Post Fri Dec 07, 2018 4:12 pm
Great troubleshooting. Perhaps Zip might know an answer about the status not being reported, but as long as everything is working it's not too critical. :D
Plohish
Post Sat Dec 08, 2018 7:26 am
good day!
I have news :)
I took up research ...
command
ps -wwwwaU dlna | grep java
gives the following result:
user@plohish67:~ # ps -wwwwaU dlna
  PID TT  STAT    TIME COMMAND
61512  2- I    1:47.71 /usr/local/openjdk8/bin/java -Xmx512M -Xms20M -XX:+UseG1GC -XX:GCTimeRatio=1 -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20
 -Djava.net.preferIPv4Stack=true
 -Djava.awt.headless=true
 -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade
 -Dderby.system.home=/var/db/serviio
 -Dserviio.home=/var/db/serviio/home
 -Dffmpeg.location=/usr/local/bin/ffmpeg
 -Ddcraw.location=/usr/local/bin/dcraw
 -Djcs.auxiliary.DC.attributes.DiskPath=/var/db/serviio
 -classpath /usr/local/share/java/classes/serviio/serviio.jar:
 /usr/local/share/java/classes/serviio/aXMLRPC.jar:
 /usr/local/share/java/classes/serviio/commons-codec.jar:
 /usr/local/share/java/classes/serviio/commons-imaging.jar:
 /usr/local/share/java/classes/serviio/commons-io.jar:
 /usr/local/share/java/classes/serviio/commons-jxpath.jar:
 /usr/local/share/java/classes/serviio/commons-lang.jar:
 /usr/local/share/java/classes/serviio/commons-logging.jar:
 /usr/local/share/java/classes/serviio/concurrent.jar:
 /usr/local/share/java/classes/serviio/derby.jar:
 /usr/local/share/java/classes/serviio/freemarker.jar:
 /usr/local/share/java/classes/serviio/groovy-all.jar:
 /usr/local/share/java/classes/serviio/gson.jar:
 /usr/local/share/java/classes/serviio/httpclient-cache.jar:
 /usr/local/share/java/classes/serviio/httpclient.jar:
 /usr/local/share/java/classes/serviio/httpcore.jar:
 /usr/local/share/java/classes/serviio/icu4j.jar:
 /usr/local/share/java/classes/serviio/imgscalr-lib.jar:
 /usr/local/share/java/classes/serviio/jISO8601.jar:/usr
 /local/share/java/classes/serviio/jaudiotagger.jar:
 /usr/local/share/java/classes/serviio/jcl-over-slf4j.jar:
 /usr/local/share/java/classes/serviio/jcs.jar:
 /usr/local/share/java/classes/serviio/jdom.jar:
 /usr/local/share/java/classes/serviio/jnat-pmplib.jar:
 /usr/local/share/java/classes/serviio/jul-to-slf4j.jar:
 /usr/local/share/java/classes/serviio/log4j.jar:
 /usr/local/share/java/classes/serviio/lucene-analyzers-common.jar:
 /usr/local/share/java/classes/serviio/lucene-core.jar:
 /usr/local/share/java/classes/serviio/org.restlet.ext.gson.jar:
 /usr/local/share/j
I can't see this the line - org.serviio.MediaServer
I fixed the startup script like this:
the string
pc5dczc_pid=$(ps -wwwaU ${pc5dczc_user} | awk '/java.*org.serviio.MediaServer/ {print $1}')
replaced by
pc5dczc_pid=$(ps -wwwaU ${pc5dczc_user} | awk '/java/&&/serviio/ {print $1}')
it works!
user@plohish67:/letc/rc.d# /usr/local/etc/rc.d/serviio status
serviio is running as pid 61512
does my code have a right to exist?
Post Sun Dec 09, 2018 9:52 am
Serviio doesn't come by default with the service support on Linux, just a .sh file. Where did you get this build?
Plohish
Post Sun Dec 09, 2018 9:57 am
zip wrote:Serviio doesn't come by default with the service support on Linux, just a .sh file. Where did you get this build?
I compiled this program from the standard ports of Freebsd 11.2
/usr/ports/net/serviio
Post Sun Dec 09, 2018 10:01 am
ah ok, so I guess you'll have to ask the maintainer
Users browsing this forum: Google [Bot] and 38 guests
