New user: How to redo metadata?
sand
Post Mon Dec 10, 2018 2:05 pm
I have some anime which Servio is picking up as movies. The main two are Bleach and Cool Hand Luke. How do I reset the metadata or tell Servio that these are not movies but series
Post Mon Dec 10, 2018 8:35 pm
Re: New user: How to redo metadata?
sand wrote:I have some anime which Servio is picking up as movies. The main two are Bleach and Cool Hand Luke. How do I reset the metadata or tell Servio that these are not movies but series
Files must be named a particular way for the online meta-search to pick them up correctly. TV episodes must have SxxExx in the name with S being the season number and E the episode number. You can go to thetvdb.com and see how your particular episodes should be labeled. Renaming the file will cause Serviio to remove the old name from the database, add the new name, and search for the metadata to match.
This page also offers good guidance. http://www.serviio.org/index.php?option ... icle&id=12
sand
Post Wed Dec 12, 2018 12:13 pm
Thanks for the reply. I had seen this mentioned in other posts but had hoped there was a way to edit the data manually.
freaknik
Post Wed Dec 12, 2018 3:09 pm
I use the setting from the console xbmc nfo files and then you can use kodi and edit the metadata from text based nfo.
It's tedious but can be done.
Users browsing this forum: No registered users and 60 guests
