(Solved) after upgrade to 1.10 (on Linux) no login possible
enzephalon
Post Thu Dec 06, 2018 7:42 pm
Tonight I upgraded to Serviio 1.10 .
The upgrade worked, I copied config and library and restartet service.
Console was working fine.
But there was no possibility to login to mediabrowser (no error shown, just login-screen) or login via ServiGo-App (error-message: "your session was outdated, you were logged out").
Good to know: in 1.10 there was no log-directory and no logfiles! I tried to make a log-dir, but still no files in it.
I downgraded to 1.9.2 and all worked fine as expected.
I think there is something broken in 1.10 but because there are no logfiles, I cannot say what the fault.
Any ideas?
Best regards
Johannes
enzephalon
Post Mon Dec 17, 2018 9:40 am
Re: after upgrade to 1.10 (on Linux) no login possible
Hello
Today I tried 1.10.1 - I was hoping the login-problem was fixed. But sadly, it doesn't.
I'm still not able to log into mediabrowser or by ServiGo-App into 1.10.x !
But (as improvement to 1.10) we have something in our LOG:
2018-12-17 10:36:45,132 WARN  [ServiioStatusService] AuthenticationException occurred. Returning error code 401 to the REST layer. Message: The provided authentication token is invalid or expired.
org.serviio.restlet.AuthenticationException: The provided authentication token is invalid or expired.
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.LoginServerResource.validateToken(LoginServerResource.java:72)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:56)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:1014)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.handle(CDSBrowseServerResource.java:124)
   at org.restlet.resource.Finder.handle(Finder.java:246)
   at org.restlet.routing.Filter.doHandle(Filter.java:159)
   at org.restlet.routing.Filter.handle(Filter.java:206)
   at org.restlet.routing.Router.doHandle(Router.java:431)
   at org.restlet.routing.Router.handle(Router.java:648)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
   at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
   at org.restlet.Application.handle(Application.java:384)
   at org.restlet.Component.handle(Component.java:406)
   at org.restlet.Server.handle(Server.java:516)
   at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:72)
   at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
   at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:80)
   at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
   at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
   at java.lang.Thread.run(Thread.java:748)
Best regards
Johannes
enzephalon
Post Mon Dec 17, 2018 9:54 am
[SOLVED] after upgrade to 1.10 (on Linux) no login possible
Because of the authentication-token-error from the serviio.log I tried to re-enter my password. But if you enter the same password as before, you can't save it. So you have to first enter a different password, save that and then enter your desired password (which you had before) and save.
After that I was able to log in!
Yeah!
Post Mon Dec 17, 2018 4:51 pm
Nice troubleshooting. Good job!
Users browsing this forum: Google [Bot] and 50 guests
