Server won't disconnect from Roku Media Player
scottrobik
Post Tue Dec 18, 2018 8:55 pm
I've been using the Serviio media server in conjunction with the Roku media player. I want to be able to "disconnect" the media server from the play, but no matter what I do the server still shows as connected. I have quit/stopped the server. Uninstalled the server from the home laptop that I've hosed to host it. Restarted the Roku media player as well as rebooted the Roku device to no avail. No matter what I do the server still show in the device list of the Roku media player. Please can someone tell me how to disconnect/remove the server? Thank you.
Post Wed Dec 19, 2018 1:14 am
Re: Server won't disconnect from Roku Media Player
There is no saved connection between the Roku and Serviio. When Roku Media Player is started, it searches your network for any DLNA media server. If none are found, you won't see anything in RMP. If Serviio is running, it will always appear. But there's no connection between the two (other than the original search) until you access the DLNA server and start browsing for media and select something. Roku has no internal storage that remembers what servers have been connected in the past. It only lists what is available at the time.
What exactly are you attempting to do? If you don't want Serviio to be listed as an available source, you can disable the DLNA server function on the Serviio console on the Status tab at the bottom. But then Serviio isn't available to anything else on your network either.
Post Wed Dec 19, 2018 7:15 pm
I just finished reading your post on the Roku forum, and you offered some additional info.
There is no reason to "remove" Serviio from RMP. You can run multiple DLNA media servers on the same computer without issue, as long as they use different ports. I've had several running at the same time on my Windows PC without issue before. If you don't want to use Serviio at all any more, then just uninstall it. If you're just testing a different brand, go ahead and install it alongside Serviio. Unless it tries to use the same port, they won't interfere with each other.
Users browsing this forum: No registered users and 53 guests
