Samsung C series TV PL50C7705 specific mkv file not playing
grisbilen
Post Tue Mar 29, 2011 11:54 pm
Was hoping someone could help debug this one:
Does NOT work:
Unique ID                        : 192144013668939992942443775476400973857 (0x908D9748E40F1B1A818D245297E0E821)
Complete name                    : D:\Media\Serier\Battlestar Galactica (2003)\Season 2\Battlestar Galactica S02E02.mkv
Format                           : Matroska
File size                        : 1.09 GiB
Duration                         : 42mn 5s
Overall bit rate                 : 3 721 Kbps
Encoded date                     : UTC 2006-09-08 09:58:16
Writing application              : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
Writing library                  : libebml v0.7.7 + libmatroska v0.8.0
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 13 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 42mn 5s
Bit rate                         : 3 333 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.151
Stream size                      : 983 MiB (88%)
Writing library                  : x264 core 50 svn-557M
Encoding settings                : cabac=1 / ref=10 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=2 / nr=0 / decimate=1 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=3333 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 42mn 5s
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 116 MiB (10%)
Language                         : English
Does work:
Unique ID                        : 181379348725478782501919740519276883837 (0x88746453956AC2409AE46BE2627C2F7D)
Complete name                    : D:\Media\Serier\Battlestar Galactica (2003)\Season 1\Battlestar Galactica S01E01.mkv
Format                           : Matroska
File size                        : 1.08 GiB
Duration                         : 44mn 35s
Overall bit rate                 : 3 456 Kbps
Encoded date                     : UTC 2006-11-20 18:46:47
Format settings, ReFrames        : 11 frames
Duration                         : 44mn 35s
Bit rate                         : 3 083 Kbps
Height                           : 720 pixels
Bits/(Pixel*Frame)               : 0.140
Stream size                      : 958 MiB (87%)
Writing library                  : x264 core 54 svn-598M
Encoding settings                : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / slices=2 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=3083 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language                         : English
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 44mn 35s
Bit rate                         : 384 Kbps
Bit depth                        : 16 bits
Delay relative to video          : 32ms
Stream size                      : 122 MiB (11%)
Language                         : English
Note:
The first file that isnt working didnt use to have a language set for video and audio, I added that with mkvmerge in a vain hope that it was the issue, but that didnt make any difference.
Anyone have a idea why the first file wont play?
Forgot:
ffmpeg -i provides the same exact information for the two files apart from filename and duration.
grisbilen
Post Tue Mar 29, 2011 11:56 pm
Re: Samsung C series TV PL50C7705 specific mkv file not play
Have to add: awesome program you have made, kudos on that!
Post Wed Mar 30, 2011 6:57 am
-Try remuxing this file in .m2ts with TsMuxer tool and lower h264 Profile level (5.1->4.1).
or
-Try changing only the profile level(5.1->4.1) with H264LevelEditor tool
viewtopic.php?f=17&t=2118
Post Wed Mar 30, 2011 9:48 am
Illico wrote:-Try remuxing this file in .m2ts with TsMuxer tool and lower h264 Profile level (5.1->4.1).
or
profile level is fine 5.1 will work on the samsungs i have a feeling his issue will be header compression or bitrate being to high or maybe even the simple one of he hasnt selected the correct profile in console..
grisbilen
Post Wed Mar 30, 2011 12:36 pm
or
Profile level changing does not work, and besides as mentioned, the file that do work have the same profile.
How do you know if there is header compression or not?
I'll test some more files when im at home, I had some more inconsistent results with other files also, this is just two examples.
Also, apart from the overall bitrate, the difference seems to be some encoder options, could that be the issue?
Post Wed Mar 30, 2011 12:38 pm
grisbilen wrote:
or
yes
viewtopic.php?f=6&t=1132#p5402
grisbilen
Post Wed Mar 30, 2011 12:44 pm
Thanks, I'll try it out at home later and see if i can get somewhere.
Post Wed Mar 30, 2011 3:40 pm
grisbilen wrote:Also, apart from the overall bitrate, the difference seems to be some encoder options, could that be the issue?
Yes, but it's difficult to know which encoder options interfere with the TV decoder.
grisbilen
Post Wed Mar 30, 2011 8:22 pm
I still have no idea what is wrong with those files that wont play, but i found a tool to reencode the files (just straight reencode back to the original sound/video format), and they worked.
Strange thing is that the tool reported the files being 24fps instead of the listed 23.976, dunno if that had something to do with it.
Tool used was xvid4psp v6.0
Users browsing this forum: Google Adsense [Bot] and 17 guests
