Portforwarding Help
macbroadcast
Post Mon Jan 28, 2019 12:25 am
Portforwarding Help
Hello gents
was looking for a lightweight solution to share movies with a friend and serviio seems to be the perfect solution :D
Installation worked perfectly out of the box, i have just problems with the port forwarding settings, or let's say the advanced setting in the server.
Since i am on a dynamic ip i used a service from dynu.com and a client for my mac and have apache running on port 80
to test. Adding the port 23424 at the end of my [http://myhostname.dynu.net:23424] url brought no result, so I turned of the Apache web server and port forwarded 80 to 23424, but it didn't work ether, do I miss something?
Attached screenshots of my router settings and the error i got
Everything working fine when i use "localhost" on the same machine.
Thanks for any help 8-)
Post Tue Jan 29, 2019 12:14 pm
Re: Portforwarding Help
when I do this from home, port forwarding doesn't work when I'm on my LAN. So try to hit the public IP from your 4g network, for example.
macbroadcast
Post Tue Jan 29, 2019 3:22 pm
Thanks :P, you were right, works now
Users browsing this forum: No registered users and 106 guests
