Problem with Java Installation
Markus Müller
Post Fri Nov 09, 2018 6:08 pm
I want to install on my Synology NAS DS212+ the java package which is required for serviio.
In the package center there is the installer for "Java SE Embedded 8". After starting the installation the install routine wants that I download this file "ejdk-8u181-linux-arm-sflt.tar.gz" from the oracle server.
But there ist only the newer file "ejdk-8u191-linux-arm-sflt.tar.gz". I downloaded it and put it in the public directory from my NAS. Again starting the install routine but it wants to have the file "...181..." only.
So I renamed the file to the desired name. Now the installion from the java package is done well. But I cannot start it. When I click start it takes a litte time and then it is still in stopped status.
Can anybode help me please?
Kind regards
Markus
Specialist_in_None
Post Wed Jan 30, 2019 2:37 pm
Re: Problem with Java Installation
Dear Markus,
I've the exactly same problem. Do you have a solution since your post in November?
Thanks for any advice from all,
Stefan
Meelis
Post Wed Jan 30, 2019 8:30 pm
I hope this will help. For first update nas.
See attached pic.
Java install
patters
Post Wed Apr 17, 2019 1:36 am
The Java package on my package repository has been updated to use the latest version from Oracle (1.8.0u201).
