User agent plugin
Citronel
Post Mon Jan 28, 2019 6:06 pm
User agent plugin
I was using serviio to watch online TV content from my internet provider on my old tv that support only DLNA.
Today I seen that I can't watch anything from serviio - dlna.
I checked the links on serviio and they are reported as invalid but they are 100% valid if I play them from computer on Browser or VLC.
I suspect that provider now block to play the stream if User-Agent is not a browser.
Is it possible to have a option or a working plugin to manual set the user agent that Serviio use ?
thank you.
Post Thu Jan 31, 2019 10:33 am
Re: User agent plugin
you can already define user agent via the plugin API
Citronel
Post Thu Jan 31, 2019 10:55 am
Unfortunately I can't because I have no idea how to make a serviio plugin to do just this task... and so are other 99% of users.
If you can put that option in config will be easy for everybody.
Lucky me I just tested windows version of serviio and on that OS feed links are working... I exported from Linux and imported on windows and bingo.
Citronel
Post Sat Apr 27, 2019 8:01 am
For me no need any more to run serviio or other apps.
I Installed LibreElec - Kodi on raspberry pi, imported old links that don't work on serviio any more and everything work perfect now on Kodi as IPTV / Smart Tv.
Return to Plugin development
