Mediabrowser Login "Remember Me"
kittmaster
Post Tue Jan 30, 2018 1:26 pm
I'm using Chrome as my main browser of choice, I can't seem to figure out why the remember me option doesn't work. I check it, view a few things, close the browser come back in say.......10 minutes, I have to login again.......isn't remember me supposed to maintain a cookie or something so I don't have to keep logging back in?
I've cleaned cache etc etc... it just never seems to retain.
Thoughts?
Post Tue Jan 30, 2018 1:34 pm
Re: Mediabrowser Login "Remember Me"
Mine works fine with Chrome on multiple computers. I'm not totally familiar with all of the Chrome settings, but I would expect that something has been set to either not retain cookies from MediaBrowser or sites in general.
freaknik
Post Wed Jan 31, 2018 9:42 am
Some browsers have a setting to erase all cookies after you close it so it starts fresh every time. I don't use Chrome so not sure where to look but I know Firefox has the setting. Good luck.
kittmaster
Post Sat Feb 09, 2019 11:57 pm
As of today, still having the same issue. I assume it is cookie based?
Anyone have any other thoughts?
Post Sun Feb 10, 2019 12:46 am
Yes, it uses cookies to keep you logged in. I have no issues with Chrome, Edge or IE. In Chrome, I did find a setting in the Advanced/Security/Content Settings/cookies, where cookies can be deleted when closing the browser. It's labeled "Keep local data only until you quit your browser". Mine is turned off. Perhaps yours is on.
kittmaster
Post Sun Feb 10, 2019 1:25 am
I just checked....it is off so is 3rd party.......just tested again, same issue...... I don't get it....every other site works normally...???
Post Sun Feb 10, 2019 3:54 pm
kittmaster wrote:I just checked....it is off so is 3rd party.......just tested again, same issue...... I don't get it....every other site works normally...???
Yeah, that is strange. I've run out of suggestions. Not sure if any of your extensions have the ability to whitelist sites, but if you can find that you might add it there.
Post Mon Feb 11, 2019 11:17 am
It doen't use cookies (on any modern browser), but the local session store in the browser.
kittmaster
Post Tue Feb 12, 2019 1:22 pm
Sooooooo how do I fix that......exactly?
Is that something persistent? or can be set to be?
freaknik
Post Wed Feb 13, 2019 6:56 pm
in firefox erasing profile starts fresh.
If you run at bash or cmd
firefox -P
it brings up a gui dialog with your profile, hit delete, it erases everything.
Then create new profile and start.
If that doesn't work, gasoline on the laptop, couch, whole house, burn it all, we'll regroup in Belize!
kittmaster
Post Wed Feb 13, 2019 9:22 pm
I'm using Chrome not Firefox. Same procedure?
freaknik
Post Thu Feb 14, 2019 12:33 pm
idk, chrome gives me lots of random problems like you mentioned.
If you don't like firefox use just about any other browser, I am sure problem go bye bye.
I don't use windows but the files are in a folder for your profile each os and browser.
But then you have to make a new one which I don't know how to do in chrome because i never use it.
This conversation though:
You: My crappy browser doesn't work because it's crappy
Me: So use one that works.
You: But I want to force this one to work!
Me: Image
kittmaster
Post Thu Feb 14, 2019 5:09 pm
freaknik wrote:idk, chrome gives me lots of random problems like you mentioned.
Me: Image
It is a good point, but since my entire toolchains, life, passwords and extensions all use that browser, to try and "convert" just doesn't makes sense ........does it?
Do you go out and buy a new house because the bedroom door doesn't close properly? Chances are you find a way to fix it.......and then move on.
freaknik
Post Thu Feb 14, 2019 6:08 pm
Lol can't relate, don't know what you mean by toolchains, your life is in chrome browser lol?
I don't use browser extensions and remember all my passwords or use keepass.
If the bathroom door was closing on part of my body making the house and living there untenable than yes I would leave.
Users browsing this forum: Baidu [Spider] and 35 guests
