samsung n series tv profile (i.e., nu 8000, 7100, 6900, etc)
bryon575
Post Sun Dec 09, 2018 12:59 am
can someone make it?
Post Thu Feb 07, 2019 8:16 pm
Re: samsung n series tv profile (i.e., nu 8000, 7100, 6900,
Very few TVs support any audio codecs other than PCM and AC3 (Dolby Digital). Some older sets don't even support AC3 from an external source. But as mentioned, there might be other profiles that offer sufficient processing to handle the media you have. Testing other profiles is the first and best thing to try when you have issues with playback, particularly with a Smart TV.
Unfortunately, someone has to have a particular piece of equipment (such as an N series Samsung) to be able to create a profile. But if you identify files that will play and then files that won't, we can assist with suggestions for creating a user profile that you can save and won't get lost when Serviio is updated.
Post Sat Feb 09, 2019 3:06 am
Looking at the specs it seems to play most mainstream media natively, with the exception of DTS audio. This is pretty common in newer TV's, i expect as the manufacturer can avoid paying licensing costs DTS.
Bearing in mind I haven't got this TV to test at all, I have constructed the attached profile based on simple DTS remuxing, and borrowing the header and detection blocks from the Samsung J profile. Detection may not work so you may have to manually assign the profile.
Save the attached file to your Serviio\config folder. In Serviio Console, Status tab, stop the Server (button at the bottom) and then restart it. This will reload the profiles. Check that the profile is assigned to your TV (you may need to refresh the tab) and if not manually assign it (profile is called "Samsung N Series (2018)").
Let me know how it goes.
user-profiles.xml
(1.54 KiB) Downloaded 2262 times
rrobert
Post Sun Feb 10, 2019 3:42 am
I know this is for the N series, tried it on my Q series TV and it did not work :-(
Post Mon Feb 11, 2019 1:48 am
What didn’t work? Did it load?
rrobert
Post Tue Feb 12, 2019 3:31 am
Sorry, you are right, I should be more specific.
I loaded the profile and I could see it. Assigned teh profile to my Q series TV ( I know this is a N series profile) and tried to watch some MKV with DTS enabled. MKV did not load. Samsung DNLA browser did not open the movie. Just got spinning blue circle.
Post Tue Feb 12, 2019 9:12 am
Not sure I can help. I don't have a Samsung TV but from the forums it appears some of the models in recent times had some issues handling transcoded file. I think the Q series was one of them.
Others may be able to help.
Post Tue Feb 12, 2019 1:38 pm
Yes, my JU series won't play transcoded files. At least it couldn't last time I tried. I gave up on the Samsung internal player long ago. I first used a Roku player, and now have an Nvidia Shield on that TV. The Shield plays everything without transcoding, and provides all lossless audio codecs to my AVR. And my wife still uses the Sony BD player that's connected to it as well. Neither of us could deal with the Samsung functionality any longer. I couldn't even tell you the last time I used any app in the TV itself.
Gamepat9
Post Wed Jun 05, 2019 11:02 pm
I'm sorry if this has been solved already, but I just wanted to post my custom Samsung NU8000 Profile that I created last year (I forgot to post it earlier).
It transcodes DTS to AC3 (If I remember correctly) and just streams everything else directly. The profiles I found here and tested all didn't work for me.
With this I can stream anything now (audio: dts 8-) , ac3) that I tested.
I apologize if the profile is super hacky, but it works for me. :D
user-profiles.xml
Samsung NU Series 2018
(4.35 KiB) Downloaded 2295 times
Yoongbo
Post Wed Jun 12, 2019 10:36 am
Gamepat9 wrote:I'm sorry if this has been solved already, but I just wanted to post my custom Samsung NU8000 Profile that I created last year (I forgot to post it earlier).
Hi guys, The above profile (thanks Gamepat9) allows me to watch .mkv movies with DTS audio but not fast forward/backward. Same thing with using Roku 4k TV profile for this TV.
Is anyone here having the same issues ?
The generic DLNA profile can play those mkv and allows to fast forward/backward but without sound so I don't think this is an issue of mkv file type. Is there a profile for Samsung NU TV that fixes these issues ?
Post Wed Jun 12, 2019 12:16 pm
Transcoding a file removes the ability to FF/Rewind, unless it is using the HLS transcoding format. If you've updated to Serviio 2.0, the Roku profiles now all use HLS unless the video codec is VC-1. You might try the Roku 4K TV profile again to see if it works now. The Chaneru profile also uses HLS, although it transcodes far more than your TV requires. But it would be a good test.
You are correct that it's not the MKV container. The same happens regardless of container if transcoding is necessary.
Yoongbo
Post Wed Jun 12, 2019 4:17 pm
I'm running Serviio 2.0, unfortunately neither Roku 4K TV nor Chaneru makes FF/Rewind available. Any idea why ?
Post Wed Jun 12, 2019 4:52 pm
I"d have to know the codec specifics about your media file. I know it's in a MKV container, but need the details about the audio and video codecs it contains to determine what's going on. Like I said, if the video is VC-1, the Roku profile uses a different method of transcoding that doesn't support trick play. I have no idea if a Samsung TV will play VC-1 video, although the fact you can play it without audio at least points to a supported video codec.
Yoongbo
Post Thu Jun 13, 2019 2:23 pm
atc98092 wrote:I"d have to know the codec specifics about your media file. I know it's in a MKV container, but need the details about the audio and video codecs it contains to determine what's going on. Like I said, if the video is VC-1, the Roku profile uses a different method of transcoding that doesn't support trick play. I have no idea if a Samsung TV will play VC-1 video, although the fact you can play it without audio at least points to a supported video codec.
Sry should have posted it earlier. Here are 2 of the files:
File 1: My TV can play this one and there's ff/rw but no sound. When the file is being transcoded with the mentioned profiles, I have both video and sound but no ff/rw.
Format                      : Matroska
Format version              : Version 2
File size                   : 4.36 GiB
Duration                    : 1 h 39 min
Overall bit rate            : 6 258 kb/s
Encoded date                : UTC 2011-02-24 14:20:32
Writing application         : mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
Writing library             : libebml v1.0.0 + libmatroska v1.0.0
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L4.1
Format settings             : CABAC / 5 Ref Frames
Format settings, CABAC      : Yes
Format settings, ReFrames   : 5 frames
Codec ID                    : V_MPEG4/ISO/AVC
Bit rate                    : 4 746 kb/s
Width                       : 1 280 pixels
Height                      : 720 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.215
Stream size                 : 3.22 GiB (74%)
Writing library             : x264 core 114 r1913 5fd3dce
Encoding settings           : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4746 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                    : English
Default                     : No
Forced                      : No
Format                      : DTS
Format/Info                 : Digital Theater Systems
Codec ID                    : A_DTS
Bit rate mode               : Constant
Bit rate                    : 1 509 kb/s
Channel(s)                  : 6 channels
Channel positions           : Front: L C R, Side: L R, LFE
Sampling rate               : 48.0 kHz
Frame rate                  : 93.750 FPS (512 SPF)
Bit depth                   : 24 bits
Compression mode            : Lossy
Stream size                 : 1.05 GiB (24%)
Default                     : Yes
Forced                      : No
File 1: My TV can play this one well with both video and audio and there's ff/rw. When the file is being transcoded with the mentioned profiles, I have both video and sound but no ff/rw.
Format                      : Matroska
Format version              : Version 4 / Version 2
File size                   : 4.37 GiB
Duration                    : 1 h 56 min
Overall bit rate            : 5 373 kb/s
Encoded date                : UTC 2019-06-10 20:31:28
Writing application         : mkvmerge v33.0.0 ('A Little Bit of Madness') 64-bit
Writing library             : libebml v1.3.7 + libmatroska v1.5.0
Format                      : AVC
Bit rate                    : 4 732 kb/s
Height                      : 536 pixels
Display aspect ratio        : 2.40:1
Color space                 : YUV
Bit depth                   : 8 bits
Bits/(Pixel*Frame)          : 0.288
Stream size                 : 3.85 GiB (88%)
Writing library             : x264 core 157 r2970 5493be8
Encoding settings           : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=17 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4732 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                    : English
Default                     : Yes
Forced                      : No
Format                      : AC-3
Format/Info                 : Audio Coding 3
Codec ID                    : A_AC3
Bit rate                    : 640 kb/s
Frame rate                  : 31.250 FPS (1536 SPF)
Bit depth                   : 16 bits
Stream size                 : 533 MiB (12%)
Language                    : English
Service kind                : Complete Main
Default                     : Yes
Forced                      : No
Does the codec id V_MPEG4/ISO/AVC mean it's VC-1 ? If that's the case, I guess there's no way for me to stream video with DTS sound from a device in another room to my TV and still have the ability to FF/RW :cry: I heard people invested in NAS, how could it be worth it if they had to convert audio to ac-3 for each movie ? Or are your TV simply smarter can play anything by itself ?
Post Thu Jun 13, 2019 4:30 pm
No, I don't believe codec id V_MPEG4/ISO/AVC is VC-1. The second file is playing fine because it has Dolby Digital sound (ac3). The first one has DTS sound, which requires the transcoding. I'll have to review the profiles to see why the second one is being transcoded, as it should be playable as is.
Yoongbo
Post Thu Jun 13, 2019 7:32 pm
atc98092 wrote:No, I don't believe codec id V_MPEG4/ISO/AVC is VC-1. The second file is playing fine because it has Dolby Digital sound (ac3). The first one has DTS sound, which requires the transcoding. I'll have to review the profiles to see why the second one is being transcoded, as it should be playable as is.
I'm looking forward to your finding. Please also find out why those profiles still make ff/rw unavailable. Thank you !!!
Post Thu Jun 13, 2019 11:21 pm
Any profile that transcodes will lose trick play, unless it uses HLS transcoding. I'm assuming your TV is 4K capable, but if it's not then the "Roku 1080 Media Player (2016+)" profile is a good one to test with. I'm looking at that profile now, I can't see anything that would cause your 2nd file to transcode. The only possible Matches line is looking for a video with a width of greater than 1920. Both of your files have a width of 1280, so that line should be ignoring it.
Your video is H.264, and the only lines that Match that must also match the audio codec of dts-hd or truehd, which neither of your files have. I can't find any Roku profile that would cause your file with ac3 audio to transcode except the basic "Roku Media Player" profile. Please make absolutely sure you are using a different Roku profile. IN fact, I suggest trying the Roku 4K TV profile, as that most likely matches the capabilities of your TV the closest.
If it is still transcoding the 2nd file, then I have to see a detailed log. Follow the link to see how to enable it, and make sure you delete your existing log before you run the detailed one. It gets very large quickly, so we don't need any extra information within it.
Yoongbo
Post Fri Jun 14, 2019 1:52 pm
Any profile that transcodes will lose trick play, unless it uses HLS transcoding...
Yet trick play is unavailable for me with Serviio 2.0 and Roku 4K TV profile, which like you said, uses HLS transcoding. I've always been using this profile and Serviio 2.0. So I don't understand why.
And yes my TV is 4K. Videos are streamed from my Windows 10 PC.
Below is the log. It was recorded when the second file was being streamed using Roku 4K TV profile (which made trick play become unavailable).
(425.36 KiB) Downloaded 1891 times
Post Fri Jun 14, 2019 5:22 pm
can you tell me the file name? There's almost 3000 lines to go through in the log, and that would save time for searching.
Yoongbo
Post Fri Jun 14, 2019 7:47 pm
atc98092 wrote:can you tell me the file name? There's almost 3000 lines to go through in the log, and that would save time for searching.
file name is: us.2019.720p.bluray.x264-geckos.mkv
Users browsing this forum: Baidu [Spider] and 25 guests
