Experience with Serviio Pro V 1.10.1
LaKn57
Post Tue Feb 12, 2019 9:07 pm
I have been using Serviio Pro 1.9 for some time and missed the folder option.
I have first upgraded to Serviio Pro V1.10.1 and run into several problems.
Most annoying is the server dies rather quickly.
I have then uninstalled Serviio 1.10.1 and reinstalled it.
The problem persists.
Before reinstalling again, It took more than a day to save an image folder with a lot of subfolders containing in total 1,000,000+ images.
After re-installing, the whole configuration was saved in seconds.
After having restarted the server it was busy with scanning the image folder, checking if the file already existed in the database.
In this case it suddenly dies during scanning after a few subfolders.
The scanning process for images looks slow to me, 0.3 seconds it takes to verify if the picture exists in the database.
I would like to use the V1.10.1 because of the new features.
Attached is the log file
With kind regards
LaKn57
Log file from the crash
(346.09 KiB) Downloaded 1149 times
LaKn57
Post Wed Feb 13, 2019 5:55 pm
Re: Experience with Serviio Pro V 1.10.1
Problem Solved.
After uninstalling, removing of the c:\Program files\Serviio folder and installing again, the server stays alive, unless you change the order of the shared folders. After the save, the server crashes and has to be restarted.
With kind regards,
LaKn57
Post Wed Feb 13, 2019 10:06 pm
it looks like you're running out of memory for Serviio. Change the value of Xmx in ServiioService.vmoptions file and restart the service / PC.
stevef9432203
Post Thu Jun 13, 2019 6:22 am
Spam spam spam (moderator note: spam deleted)
Return to User experiences
