Bookmarking problems on BD-C6900 - 0.5.2
I noticed zip closed the last samsung c series thread after 0.5.2 was released, but I've only used this version, and I've never gotten bookmarks to work.
Please help! Thanks
romaink wrote:Thanks for the response. yes, serviio automatically assigned my bd-c6900 to the profile "Samsung TV/Player C/D series." I'm running the latest firmware on the player too. Everything seems right. I just can't get bookmarking to work for any video. BTW, I'm a new user, so I've only used 0.5.2.
How do you remove the renders from the console?
romaink wrote:that would be 1019.0
didn't think it was needed.
romaink wrote:cerberus, I just ran an update scan and was told I had the latest firmware. I just checked the website too where 1019.0 is the last available download.
http://www.samsung.com/us/support/suppo ... e=BD-C6900
Are you sure 1020.1 is for the bd-c6900 player?
romaink wrote:thanks for the info and for the extra research!. I hope Samsung resolves the issue in the next firmware update. So... there's nothing you guys can do?
BTW, Serviio is way better than pc share manager. As soon as I can get this working right, I'll be making a donation. Thanks again!
zip wrote:Can you confirm it's not available to you with the Samsung's software either?
