Best Media Control App for Ipad ?
Paul C
Post Wed Feb 20, 2019 2:47 pm
I use the excellent BubbleUPnP control app on my Android and Kindle devices to control Serviio but it is not available for Apple devices like the Ipad (we have one in the house).
What control apps do other forum users recommend for use on the Ipad and what is their experience with them?
Post Wed Feb 20, 2019 6:29 pm
Re: Best Control App for Ipad ?
Do you mean control, or are you referring to a player for iOS? The two best options for players are Infuse and VLC. Not certain if that's exactly what you're looking for.
Paul C
Post Wed Feb 20, 2019 8:01 pm
atc98092 wrote:Do you mean control, or are you referring to a player for iOS? The two best options for players are Infuse and VLC. Not certain if that's exactly what you're looking for.
No a control app such as BubbleUPnP or Mezzmo (both on Android) not a player (renderer).
Post Wed Feb 20, 2019 9:15 pm
OK, I thought Bubble was also a player. Don't know my apps that well I guess. :oops:
Paul C
Post Thu Feb 21, 2019 11:49 am
atc98092 wrote:OK, I thought Bubble was also a player. Don't know my apps that well I guess. :oops:
You are correct. BubbleUPnP is also a player (renderer) as are most control apps.
However there is usually little value (as a player) as the sound quality of the controlling device is likely to be limited.
The main purpose is to control the use of media content on servers like Serviio and other sources and to stream it to networked devices especially high quality media streamer/player/renderers.
Infuse and VLC that you suggested look interesting options and may do the job. Any user experience anyone?
Anyone using other Control Apps on the Ipad etc?
siyavarma
Post Fri Mar 01, 2019 8:32 am
1.FamilyTime. Qustodio (Android, iOS, Kindle, Nook) Qustodio is user-friendly, efficient, and excellent for parents who are short on time. ...
2.Qustodio. ESET Parental Control (Android) ...
3.ESET. Web Watcher (Android and iOS) ...
4.Web Watcher. Norton Family Premier (Android and iOS)
Paul C
Post Fri Mar 01, 2019 11:04 am
Re: Best Media Control App for Ipad ?
Welcome but I think you are a bit off-track.
I am looking at media control software that can access the Serviio media library and deliver it to various UPnP connected devices like BubbleUPnP does on Android/kindle.
Return to General discussion
