SERVIIOSERVICE.EXE contacting InfoByIp.com and other sites
spamjam2011
Post Mon Feb 18, 2019 7:41 am
What's the reason for the service contacting these sites?
ports.yougetsignal.com:443
infobyip.com:443
canyouseeme.org
Pro User since 2011
kittmaster
Post Sun Feb 24, 2019 2:44 am
Re: SERVIIOSERVICE.EXE contacting InfoByIp.com and other sit
Most likely for the remote IP server access IP routing........would be my guess.
Post Fri Mar 01, 2019 6:15 pm
Yes, it's for checks if the remote ports are open. It also checks your public ip for the Alexa skill
spamjam2011
Post Mon Mar 04, 2019 4:54 pm
zip wrote:Yes, it's for checks if the remote ports are open. It also checks your public ip for the Alexa skill
I don't use Serviio outside of my LAN and don't use Alexa, so is there a way to prevent this type of communication?
Pro User since 2011
Return to General discussion
