Windows 10 Hyper-V default switch (two network cards)
haji
Post Sat Mar 02, 2019 3:51 pm
Since I upgrade my windows 10 to version 1809 I have a default switch (Hyper-V installed) which is can not be delete. So I have two Hyper-V virtual ethernet adapter and many times there is no bound ip address (adapter) when computer start so Serviio doesn't work (inaccessible from the network). I have to choose the proper network card via console save the settings and stop then start the server for the good working environment.
May I ask is there any permanent solution to bound the right IP address / network card ? Or is there any command line feature to script these command when the computer starts? Automatically detect settings doesn't work for me...
Thank you in advance
B.
Post Sat Mar 02, 2019 6:43 pm
Re: Windows 10 Hyper-V default switch (two network cards)
Do your cards always have the same IP address? If so, you should be able to set the Serviio network to always use the card. If they always have a different IP address, I'd assign a static IP and try that.
haji
Post Sat Mar 02, 2019 7:12 pm
first of all thank you for your answer
So, I have used fix IP address both of card (I thought) but based on your advice I have checked again and recognize that IPv6 use dhcp option so I have disable IPv6 on my network card which I want to use for Serviio.
Since then I have restarted my computer twice and it seems Serviio remember the network card settings
I hope it will be permanent
Thank you for ypur help
haji
Post Mon Mar 04, 2019 9:09 am
Finally I have found the solution. OS (windows 10 version 1809) on every start regenerated the Hyper-V default switch and changed the IP address also from a wide range pool, so I made a simple trick: I have created and scheduled a script (.cmd) at computer startup
PING localhost -n 10 >NUL
netsh interface ipv4 set address name="vEthernet (Default Switch)" static 172.17.135.54 255.255.255.0
and set Serviio service to automatic (delayed start). Therefore it always use the same ip address and Servioo keep the bound configuration properly.
Users browsing this forum: No registered users and 60 guests
