Total NOOB needs help with Sony BDP-BX57
Curvychic
Post Thu Mar 31, 2011 4:07 pm
I can see all of my video files, but several of them won't play, even though they appear to be the correct format. Most of them work great, but it would be nice if I could figure out how to play the ones that are returning the "file corrupted or unsupported" message. I've done a bit of research, but I'm totally confused!! HELP!!!
Post Thu Mar 31, 2011 4:32 pm
Re: Total NOOB needs help with Sony BDP-BX57
Curvychic wrote:I can see all of my video files, but several of them won't play, even though they appear to be the correct format. Most of them work great, but it would be nice if I could figure out how to play the ones that are returning the "file corrupted or unsupported" message. I've done a bit of research, but I'm totally confused!! HELP!!!
did you read the FAQ (link in my signiture) and the 2 sony readme's at top of this forum ?
Curvychic
Post Thu Mar 31, 2011 4:56 pm
zip wrote:http://forum.serviio.org/viewtopic.php?f=5&t=1123
Here is just of the few that doesn't work. If you need any more info from me, just let me know!!
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Rebecca>cd"\Program Files\Serviio\lib
The system cannot find the path specified.
C:\Users\Rebecca> cd "\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Rebecca\Videos\My Movies\Al
ice In Wonderland.avi
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[mpeg4 @ 01ef1fa0] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65534/
2733) -> 23.98 (24000/1001)
Input #0, avi, from 'C:\Users\Rebecca\Videos\My Movies\Alice In Wonderland.avi':
encoder : VirtualDubMod 1.5.4.1 (build 2178/release)
Duration: 01:48:36.96, start: 0.000000, bitrate: 903 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 592x320 [PAR 1:1 DAR 37:20], 23.98 tbr,
23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 112 kb/s
Curvychic
Post Thu Mar 31, 2011 4:58 pm
The FAQ didn't help and I couldn't find anything relatively close to my model number in the 2 readme's. As I said, I'm a TOTAL noob, so you're going to have dumb it down for me. LOL :)
Post Thu Mar 31, 2011 6:13 pm
have u selected the sony BDP profile in the console ???
Curvychic
Post Thu Mar 31, 2011 7:23 pm
It was automatically selected when I opened the console. It says that the Device Name and Profile are "Sony BD Player."
Post Thu Mar 31, 2011 7:57 pm
Curvychic wrote:It was automatically selected when I opened the console. It says that the Device Name and Profile are "Sony BD Player."
hmm ok must be something special about that player guess this is one for illico as he knows sonys better than me.
Curvychic
Post Thu Mar 31, 2011 8:26 pm
LOL. Well thanks for trying. :)
Curvychic
Post Fri Apr 01, 2011 4:53 am
After working on this almost all day, I finally found a solution that works for me. I just used WinAVI to convert the avi files that wouldn't play into MPEG2 files. Works like a charm!!! A little more time consuming to convert about 12 files, but they go pretty fast. Plus, I can batch convert. WAAAAY better than a NOOB trying to figure out how to make Serviio recode these files. :) Now to figure out how to make it play my mp3s.......
Post Fri Apr 01, 2011 7:15 am
Curvychic wrote:...how to play the ones that are returning the "file corrupted or unsupported" message. I've done a bit of research, but I'm totally confused!! HELP!!!
Do you use the latest 0.5.2 Serviio version?
Please, could you turn on detailed logging (see signature), you should be able to see the FFmpeg command that is used for the transcoding.
Try executing the same command manually in a terminal window and post the result here.
patters
Post Fri Apr 01, 2011 7:31 am
I have encountered a few AVIs that the player seems to reject, but this will be the player, not Serviio. You can check to see if they play from a USB stick plugged in directly.
In my case they're pretty old AVIs so from back when there were early versions of DivX etc. so they're probably badly authored. Your film seems quite new, but I guess this could still be the case. There's nothing outwardly unusual from that ffmpeg -i though.
