Re: How to fix FF/REW in .mkv files that are missing the opt
I did this as also none of the above worked for me, but it's wroth noting my serviio server is a synology NAS, so might have subtle differences.
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\Scott>cd "\Program Files\Serviio\lib"
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Scott\Desktop\Theatre\vobinmkv.mkv"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
[mpeg2video @ 03447EE0] ignoring pic cod ext after 0
Input #0, matroska,webm, from 'C:\Users\Scott\Desktop\Theatre\vobinmkv.mkv':
encoder : libebml v1.3.0 + libmatroska v1.4.0
creation_time : 2013-02-23 22:15:00
Duration: 01:52:21.12, start: 0.000000, bitrate: 5877 kb/s
Stream #0:0: Video: mpeg2video (Main), yuv420p(tv), 720x576 [SAR 64:45 DAR 16:9], max. 7500 kb/s, 50 fps, 50 tbr, 1k tbn, 50 tbc (default)
Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
C:\Program Files\Serviio\lib>kennethhall250 wrote:It's very annoying when you want to watch something and face file extension error.
