import an M3U file for IPTV
jcpamart
Post Tue Jan 22, 2019 7:21 pm
Hi everybody,
Sorry but I can't find the solution to import an m3u file I have from an IPTV provider.
I'm new and read a lot of topics but nothing very easy to use.
Thanks for your help
JC
alexsmith789
Post Fri Mar 22, 2019 8:46 am
Re: import an M3U file for IPTV
When I was trying to import the files then suddenly lenovo screen flicker started and I could not complete the import. Please help me to fix it so that I can import the files again.
Mukesh Kumar
Post Tue Apr 25, 2023 1:28 pm
Sorry for bumping into an old conversation. First, you'll need an IPTV player installed on your device, such as VLC or Kodi. Then, you can import the M3U file by going to the player's "Playlist" or "Channels" section and selecting "Import" or "Add playlist." From there, you'll need to browse to the location where you saved the M3U file and select it. If you need an alternative, consider cable tv, like https://flussonic.com/cable-tv/. I hope that helps!
qrodrigob
Post Sun May 14, 2023 2:43 pm
jcpamart wrote:Hi everybody,
JC
If you guys are still looking for a converter from .m3u file extension to .ob file extension
I created a script for this in python.
Then just mold according to each configuration you need
https://canalqb.blogspot.com/2023/05/ubuntu-server-serviio.html :P :P :P
Return to Available plugins
