Online source... blank !
JunJun
Post Sun Mar 24, 2019 12:53 pm
Well, I'm using Serviio for a couple of years now, and it seems that I can't display online sources anymore...
I don't have any problem streaming music/video from computer to TV with Serviio.
I tried to add some online contents such as Twitch for video, and TuneIn for music. I installed the according plugins into the HD/Library/Application Support/Serviio/plugin folder and even restarted Serviio.
One of the links entered is https://tunein.com/radio/Radio-NARITA-837-s238381/
I selected 'Audio', and 'Web Resource'
The link works with my web browser, but Serviio URL stream check say the link is not valid or not currently available...
On TV, I go to Audio => Online Content => nothing appears....
Same goes with videos, where I tried with a Twitch channel ('Video' and Web resource)...
Is there something I'm missing ???
Thanks !
Serviio v1.10.1, iMac with Mojave 10.14.3, TV Toshiba.
Post Fri Mar 29, 2019 10:04 am
Re: Online source... blank !
It's possible that the plugin is broken.
Will have a look if I find the time.
Post Sat Mar 30, 2019 10:12 pm
I've updated the plugin, try to get the new version.
JunJun
Post Mon Apr 01, 2019 9:08 am
Thanks !
I have the list now, but streams don't play : some give a message 'not compatible with the player', others play 2 secondes then stop...
Oh well.... :(
olivier
Post Sun Oct 11, 2026 12:27 pm
I Have trouble to use Online Audio Source Source.
I use Serviio installed on a Synology NAS DS413 on DSM6.2
When i create one Online Sources in the Library for example Nostalgie Radio
with a live stream https://streaming.nrjaudio.fm/oug7girb9 ... fluxradios
URL check is OK.
Unfortunately i am not able to see this online source in the MediaBrowser (list is always empty); this is also valid with
any other DNLA app, the online created sources are not visible.
Could you please help to find the missing step in my config ?
Many thanks.
BR Olivier
Users browsing this forum: Google [Bot] and 31 guests
