aspect ratio
Berny
Post Fri Apr 01, 2011 10:51 am
Re: aspect ratio
To ZIP
Almost all profiles read my files (except 2 or 3) but ratio problem is the same (on some ratio is 4/3).
One good new, my AVCHD files which cannot be readen natively on the viera, if i do not use the panasonic support, are well transcoded (remuxed) by Serviio and not on the other media servers i used.
As those files are all 16/9, no problem with the aspect ratio.
Please note that using the av controller, the url from servioo is readen with the correct 21/6 ratio on my laptop (no black bars).
Properties of the file is:
FORMAT: QuickTime/MPEG-4/Motion JPEG 2000 format
Video CODECS: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
Audio CODEC: AAC
Berny
dave
Post Fri Apr 01, 2011 11:45 am
Re: aspect ratio
Do we have a list of which servers get this correct?
I only have serviio installed but I could experiment with something else if we can learn from it.
Berny
Post Mon Apr 04, 2011 4:45 pm
Re: aspect ratio
Well, i found why my 21/6 films have a 16/9 aspect ratio.
Those films are 1280x544, if i convert them to 1280x720, the films are played in 16/9 with 2 black bars, which gives the correct 21/6 aspect ratio on my Viera's.
Question:
Is it possible to remux or transcode from 1280x544 to 1280x720 with Servioo or do i have to convert all my files with the native 21/6 ratio?
I guess that the other media servers transcode the films to 16/9
Berny
Post Mon Apr 04, 2011 5:19 pm
Re: aspect ratio
Berny wrote:Well, i found why my 21/6 films have a 16/9 aspect ratio.
Question:
Berny
There is a way to change aspect ratio using FFMPEG during transcoding, but that would mean transcoding EVERY file and that would be very resource hungry. So you would be better off converting all your files.
Berny
Post Mon Apr 04, 2011 5:41 pm
Re: aspect ratio
Thanks, that what i thought, but how are doing the others??
Berny
Post Mon Apr 04, 2011 7:09 pm
Re: aspect ratio
Berny wrote:Thanks, that what i thought, but how are doing the others??
Berny
no idea i only use serviio ;)
dave
Post Fri Apr 08, 2011 11:15 am
Re: aspect ratio
Berny, have you used another media server that gets the aspect ratio correct with the same films?
Which media server was it?
Berny
Post Fri Apr 08, 2011 12:07 pm
Re: aspect ratio
dave wrote:Berny, have you used another media server that gets the aspect ratio correct with the same films?
Hello Dave,
Correct ratio with Mezzmo and WMP 12, i don't use anymore other media servers.
I would prefer Servioo for many reasons, but i have some other "display" problems to be resolved before letting down the others.
Post Fri Apr 08, 2011 12:32 pm
Re: aspect ratio
Hello Dave,
wmp 12 - does not comply to the DLNA standard so cant not be compared to serviio
Mezzmo - is pay for software so again can not be compared to free software like serviio, plus its only availible on windows so linux and mac users are out of luck.
Post Fri Apr 08, 2011 12:51 pm
Re: aspect ratio
Cerberus wrote:Mezzmo - is pay for software so again can not be compared to free software like serviio, plus its only availible on windows so linux and mac users are out of luck.
I want to compare to them ;-) I want to beat them :-D
Post Fri Apr 08, 2011 2:28 pm
Re: aspect ratio
we do compare BUT with money comes faster evolution of the product as we are relient on FFmpeg for some of our functions and we already beat then as we run on linux and mac..
Berny
Post Fri Apr 08, 2011 5:00 pm
Re: aspect ratio
Cerberus wrote:wmp 12 - does not comply to the DLNA standard so cant not be compared to serviio
Well, wmp works fine with my tv sets & other renderers and it is windows 7 native :)
Mezzmo, yes i paid $30 if i remember, but i don't mind paying for a software if it gives what i'm looking for.
Linux & Mac..... i'm not concerned ;)
Berny
Post Fri Apr 08, 2011 5:04 pm
Re: aspect ratio
Berny
yer berny but there more than just you reading these forum ;)
rowla
Post Sat Jul 23, 2011 5:38 am
Re: aspect ratio
(bump)
i'm having similar problems with files being played to my panasonic tc-p42s30.
this TV can play x264+AC3, mkv or mp4 container natively, but of course sometimes there is a need to remux the file (wrong language track is selected by default, DTS audio instead of AC3, etc).
however when remuxing the aspect ratio is ruined and the TV won't scale intelligently. in fact i can't figure out what it's doing at all, a 1920x800 output image will end up shrunken on the screen...
i'm using the usual MKV/x264->mpegTS tactic because that seems to generate the most stable containers for the TV, but no matter how I use the pad options etc i can't get a good, non shrunk/distorted image.
seems like the panasonic dlna video browser is flaky, but anyone have any fixes yet? i'm using ffmpeg to remux or transcode...
tomikaa87
Post Thu Aug 11, 2011 8:49 pm
Re: aspect ratio
I just ran into this aspect ratio issue and looked around the web but without any success. I have a Panasonic TX-L32D25E and every video with a non-native resolution showed incorrectly.
I found a possible solution on this site: http://blog.komeil.com/2006/09/modify-mp4-aspect-ratio-mp4box-mpeg4.html. It mentions the Pixel Aspect Ratio that can be changed in the video container without re-encoding the file. What do you think? This MP4Box util could do the trick?
Post Fri Aug 12, 2011 6:44 am
Re: aspect ratio
tomikaa87 wrote:What do you think? This MP4Box util could do the trick?
Don't think MP4box is the solution...
ffmpeg implement some extra option, like "-s" to change/scale the output format, "-aspect" to change the output aspect ratio.
Also, ffmpeg implement advance filtering like, "-vf scale" to change/scale the output format (like -s), "-vf pad" to add padding black bar, "-vf setdar" to change display aspect ratio without change images.
I'm working on a solution for Sony Bravia TV display aspect ratio issue: viewtopic.php?f=11&t=2956
tomikaa87
Post Fri Aug 12, 2011 6:02 pm
Re: aspect ratio
I have checked your solution but it's impossible to use as a real-time transcoding method on a slower machine. I tried to find a solution that doesn't need to re-encode the whole video, but with just remuxing it seems to be impossible.
Scoootch
Post Wed Aug 17, 2011 7:24 pm
Re: aspect ratio
I've exactly the same problem. It seems that muxing to m2ts doesn't work always. This works only with PS3 Media Server through PS3. PMS has the same problem through Panasonic TV. For the right ratio through PS3, PMS remuxes. It only transcodes MKV when they are subtitles. PMS use MEncoder.
If this can help
EDIT :
With MediaInfo only these mkv are in the good ratio :
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio        : 16:9
AND
Width                            : 1 920 pixels
Height                           : 1 080 pixels
These mkv are in the bad ratio :
Height                           : 528 pixels
Original display aspect ratio    : 2.40:1
Height                           : 528 pixels
Display aspect ratio             : 2.40:1
Height                           : 720 pixels
Original height                  : 528 pixels
BUT all these mkv are in the good ratio with Serviio through PS3
rlar
Post Wed Feb 29, 2012 6:44 pm
Re: aspect ratio
If no alternative solution has been found to this problem I would be interested in trying the real-time transcoding. Is there a configuration file which enable this transcoding or should I try to write it down (I don't have any idea about how to do it, but I hope to be able with some effort)
Post Wed Feb 29, 2012 7:32 pm
Re: aspect ratio
Scoootch wrote:BUT all these mkv are in the good ratio with Serviio through PS3
PS3 Media Server use same workaround with mencoder option to pad video into 16:9 and change DAR to 4:3
Return to Panasonic
