serviion centos 7 install
jorometala
Post Thu Mar 28, 2019 8:50 pm
I followed the this https://wiki.serviio.org/doku.php?id=howto:linux:install:centos7 tutorial.
Everything went without errors. But Serviio refuse to start.
Actually it started onece then I restarted it and it refuse to start. Here is the log:
2019-03-28 20:30:55,093 INFO  [LibraryDeltaScanner] Starting the library delta scan
2019-03-28 20:30:55,097 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2019-03-28 21:16:09,957 INFO  [RendererManager] Stored a new renderer: uuid='52cf3aea-a25d-4a36-8c8b-168f13bfd7bd', name = 'Unrecognized device', ipAddress='192.168.2.114', profile = '1', accessGroupId = '1'
2019-03-28 21:24:22,521 WARN  [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2019-03-28 21:24:22,521 WARN  [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2019-03-28 21:24:22,523 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2019-03-28 21:24:22,524 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2019-03-28 21:24:22,524 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2019-03-28 21:24:22,725 INFO  [LibraryOneTimeScanner] Interrupting library scan
2019-03-28 21:24:22,725 INFO  [LibraryDeltaScanner] Stopping the library delta scan
2019-03-28 21:24:22,727 INFO  [PlaylistMaintainerWorker] Finished looking for playlist changes
2019-03-28 21:24:22,827 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2019-03-28 21:24:22,827 INFO  [FeedUpdaterWorker] Finished looking for online resources information
2019-03-28 21:24:22,927 INFO  [PluginCompilerThread] Finished looking for plugins
2019-03-28 21:24:23,037 INFO  [SearchIndexer] Closing search index writer
2019-03-28 21:24:23,040 INFO  [SearchIndexer] Closing search index writer
2019-03-28 21:24:23,056 INFO  [RendererSearchSender] Stopping Renderer searcher process
2019-03-28 21:24:23,056 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2019-03-28 21:24:23,057 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2019-03-28 21:24:23,057 INFO  [WebServer] WebServer shutting down
2019-03-28 21:24:23,058 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2019-03-28 21:24:23,058 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2019-03-28 21:24:23,058 INFO  [EventDispatcher] Leaving EventDispatcher
2019-03-28 21:24:23,059 INFO  [DatabaseManager] Shutting down database
2019-03-28 21:24:23,168 WARN  [DatabaseManager] DB shutdown returned: Derby system shutdown.
2019-03-28 21:24:23,168 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2019-03-28 21:56:06,547 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2019-03-28 21:56:06,548 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2019-03-28 21:56:31,943 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
versions:
serviio 1.10.1
fisrt and only successful start with > java-1.8.0-openjdk-1.8.0.201.b09-2
then I uninstalled it and replace it with > java-1.7.0-openjdk-1.7.0.211-2.6.17.1
and last > java-11-openjdk-11.0.2.7-0
ffmpeg.x86_64 2.8.15-1.el7.nux @nux-dextop
ffmpeg-libs.x86_64 2.8.15-1.el7.nux @nux-dextop
now I'm stuck with "Port is already taken. Notifying first instance" every attempt to start logs that message.
I tried:
- reboot > no change
- ps fax do not show any java or so process running
  1 ?        Ss     0:00 /usr/lib/systemd/systemd --switched-root --system --deserialize 22
 1859 ?        Ss     0:00 /usr/lib/systemd/systemd-journald
 1880 ?        Ss     0:00 /usr/sbin/lvmetad -f
 1885 ?        Ss     0:00 /usr/lib/systemd/systemd-udevd
 3596 ?        S<sl   0:00 /sbin/auditd
 3624 ?        Ssl    0:00 /usr/lib/polkit-1/polkitd --no-debug
 3626 ?        Ss     0:00 /usr/lib/systemd/systemd-logind
 3629 ?        Ss     0:00 /usr/sbin/irqbalance --foreground
 3630 ?        Ss     0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
 3636 ?        Ssl    0:00 /usr/sbin/NetworkManager --no-daemon
 3638 ?        Ss     0:00 /usr/sbin/crond -n
 3660 ?        S      0:00 /usr/sbin/chronyd
 3670 tty1     Ss+    0:00 /sbin/agetty --noclear tty1 linux
 3926 ?        Ssl    0:00 /usr/bin/python2 -Es /usr/sbin/tuned -l -P
 3927 ?        Ss     0:00 /usr/sbin/sshd -D
 4464 ?        Ss     0:00  \_ sshd: root@pts/0
 4466 pts/0    Ss     0:00      \_ -bash
 6360 pts/0    R+     0:00          \_ ps fax
 3928 ?        Ssl    0:00 /usr/sbin/rsyslogd -n
 4284 ?        Ss     0:00 /usr/libexec/postfix/master -w
 4290 ?        S      0:00  \_ pickup -l -t unix -u
 4291 ?        S      0:00  \_ qmgr -l -t unix -u
- netstat -ntapu:
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      3927/sshd
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      4284/master
tcp        0    232 192.168.2.2:22          192.168.2.114:50080     ESTABLISHED 4464/sshd: root@pts
tcp6       0      0 :::22                   :::*                    LISTEN      3927/sshd
tcp6       0      0 ::1:25                  :::*                    LISTEN      4284/master
udp        0      0 127.0.0.1:323           0.0.0.0:*                           3660/chronyd
udp6       0      0 ::1:323                 :::*                                3660/chronyd
this is fresh installation of centos 7 minimal
please help
freaknik
Post Sat Mar 30, 2019 2:38 am
Re: serviion centos 7 install
I think java 11 is too new? Doesn't Serviio need 8 or 9?
jorometala
Post Mon Apr 01, 2019 9:59 pm
freaknik wrote:I think java 11 is too new? Doesn't Serviio need 8 or 9?
Yes probably but it was my last desperate attempt. I had no luck with 7 and 8 .
Post Wed Apr 03, 2019 9:25 am
Is should work with at least Java 8. Java 11 should also work, but 8 is the best version atm.
The port taken message means the process is already running.
Users browsing this forum: No registered users and 86 guests
