Help creating a profile for Sony Google TV NSZ-40GT1
pixelwix
Post Sat Apr 02, 2011 6:44 am
all my media file play fine except for the files that seem to have pcm_bluray audio
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "D:\BlueRay Movies\Harry Potter
7 Part 1.mpg"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[mpegts @ 012fbc10] max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, mpegts, from 'D:\BlueRay Movies\Harry Potter 7 Part 1.mpg':
Duration: 02:26:05.30, start: 599.958300, bitrate: 6885 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1280x536 [PAR 1:1 DAR 160:67], 23
.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0.1[0x1100]: Audio: pcm_bluray, 48000 Hz, stereo, s16, 1536 kb/s
this is the file info.. any help on how i can transcode the audio so it will play with ps3 profile would be most helpful thanks in advance
Post Sat Apr 02, 2011 8:32 am
Re: Help creating a profile for Sony Google TV NSZ-40GT1
Please Provide supported formats of a device so that a profile for this device can be made. ( howto link in my signiture ) then test your device using the GENERIC profile and provide details of files that wont play ( howto link in signiture )...
Post Sat Apr 02, 2011 10:44 am
I assume you're using the Bravia profile.
Find this in your profiles.xml (in the Bravia profile):
<!-- if audio different to ac3, must be transcoded -->
and add this line underneath:
<Matches container="mpegts" aCodec="lpcm" />
Save profiles.xml and restart the service.
pixelwix
Post Tue Apr 05, 2011 10:19 pm
i'm using the sony bluray player profile, the bravia profile doesn't play any of the movies. could you give me settings for the bluray profile?
mrecio
Post Thu Apr 07, 2011 4:43 pm
I also have this TV and would love a specific profile for it.
I am a new user of Serviio (got it two days ago) and think its the best server out of the 5 I tried. The built in Bravia profile works flawlessly with my 32EX308 Bravia TV however it does not work at all with the NSX-40GT1. the supported formats are different. As far as I can tell from the sony website the Google TV supports the following
AAC/MPEG4-AAC
H.264/MPEG-4 AVC
MP3 MPEG-1 Audio Layer
It doesnt mention DLNA support but the built in media player does see the server and plays almost everything fine with the generic profile however I have run into a few movies that do not play audio.
I am new to all this codec stuff but AAC and MP3 are the only supported audio? if so how would I create a profile that transcodes audio but leave video alone and keeps the MPEG4 format?
Post Thu Apr 07, 2011 5:05 pm
mrecio wrote:I also have this TV and would love a specific profile for it.
AAC/MPEG4-AAC
H.264/MPEG-4 AVC
you need to provide some details on the device and on the files that wont play. (see my signiture for links )
mrecio
Post Thu Apr 07, 2011 5:53 pm
I will try to provide all the info I can, however I am not at home and am RDPing into my server to get this info. I dont think the UPnP software can scan my TV as the TV is off lol. so the only info I can give you is whats on sony's site, is that not adequate? Ive turned on detailed logging but its not going to log anything until I get home and use the service.
I tried using ffmpeg to get video file info but keep getting a permission issue for some reason? I have full access to the file but FFmpeg is not playing nice.
any suggestions?
