default access group (pro version) not limiting access...
ricobico
Post Sun Apr 28, 2019 7:19 pm
Hello.
I was having issues with every device in my home network automatically connecting to serviio 9or the other way around). I bought pro version so that I could limit access to three specific devices. However, this does not see to do anything. I am still having issues with devices connecting.
any thoughts?
Post Mon Apr 29, 2019 12:03 am
Re: default access group (pro version) not limiting access..
Confirm on the status page of the console that you have Default Access Group set to Limited Access and "Enable access for new devices" is not checked. The second item is most important. If that is unchecked, no player should be able to access any content until you grant them access.
User groups are coming in the next version of Serviio, but I don't know when that will be available. But I think he's getting close.
ricobico
Post Tue Apr 30, 2019 12:21 am
thanks for the reply.
yes, both o those are checked. that's why I am confused. It should only be the 2 wd tv devices and the samsung tv.
Post Tue Apr 30, 2019 1:23 am
I can see my the background tint that they show as disabled devices. Zip will likely need a copy of your log to research the problem, as that certainly isn't working as expected.
ricobico
Post Tue Apr 30, 2019 8:34 pm
atc98092 wrote:I can see my the background tint that they show as disabled devices. Zip will likely need a copy of your log to research the problem, as that certainly isn't working as expected.
Thank you. I don't know what "Zip will likely need a copy of your log to research the problem" means or how to go about this.
Post Tue Apr 30, 2019 11:29 pm
Sorry. Zip is the person that created and maintains Serviio. He will want to see your log to look for any errors occurring. I don't know what operating system you are using, but in Windows the default Serviio install location is c:\Program Files\Serviio. There is a Logs folder within the install location. Find the file Serviio.log, compress the file, and add it as an attachment to a post here.
ricobico
Post Wed May 01, 2019 2:51 am
thank you. Attached is everything from the file location.
log.7z
(350.35 KiB) Downloaded 398 times
Post Wed May 01, 2019 9:16 pm
Are they actually connecting? There might be something cached on the devices. Can you actually browse Serviio on them?
Users browsing this forum: No registered users and 56 guests
