Boxee Box I can't see the external subs
sheru
Post Mon May 13, 2019 1:20 pm
I set up my boxee box without transcoding cause I can read all the files there. All I need is working good. I can see the internal subs for example inside a MKV, but when is external named with the same name of the movie and it's an .srt file I can't see there. I have the subtitles option activated and I read in the web the server allows .srt external so idk what happen.
Post Tue May 14, 2019 9:11 pm
Re: Boxee Box I can't see the external subs
it's likely the box doesn't support external subtitles via DLNA
sheru
Post Wed May 15, 2019 4:42 pm
But I can see the subs inside the mkv. idk im not sure. Which boxes i should active in serviio to see this kind of subs?
Post Wed May 15, 2019 6:51 pm
that's different. embedded subs might be supported, but not the external ones.
You'd have to enable burning-in subtitles in the console, which will trigger transcoding.
sheru
Post Fri May 17, 2019 9:12 am
I have disabled the transcoding section cause with my boxee i can read all. But I have activated all the subs stuff. Must be activated the general transcoding to work external subtitles?
lagunaa
Post Fri May 17, 2019 2:14 pm
sheru wrote:Must be activated the general transcoding to work external subtitles?
As stated before, if your Boxee Box doesn't support external subtitles via DLNA, which seems to be the case, you have to enable burning-in subtitles to get external subtitles working.
Cheers.
sheru
Post Sat May 18, 2019 1:00 pm
okey works. The files appear when they have subs as 8.2 GB. And when is largest file is very slow charging but more light files works better. This transcoding when the movie finishes save some temporal files in the computer? And the option of opensubtitles would work in the boxee? you know that?
Users browsing this forum: Google [Bot] and 69 guests
