Serviio 2 MetaData Lookup Wrong
mike.clayton999
Post Wed May 29, 2019 8:30 pm
Hi Just upgraded to Serviio 2 and noticed that some of the MetaData lookups that were correct on earlier versions of Serviio are now incorrect.
The 100, Season 1 Episode 1 is now showing as series 100% and the episode is called planes. All the other episodes of 100 are correct and appear under the correct series. I have tried moving the file out the folder and back in to force rediscovery but still comes up as series 100% Episode 1 Planes instead of The 100 - Pilot
[MediaFileIndexer] Added file 'X:\WEB\Film\Series\The_100\S01E01-Pilot [The 100].mp4' (title: Planes) to Library
I have tried changing the folder name from The_100 to The 100 but after the scan updates I still have All the 100 under the correct series except for episode 1
I looked on www.theTVDB.com and there is a series called 100% which has one Episode called Planes. I am Guessing in the fussy logic search the % is getting treated as a wild card and messing up the match.
Mike
Post Wed May 29, 2019 9:00 pm
Re: Serviio 2 MetaData Lookup Wrong
Sometimes the logic does get confused, you are correct. The rare times I've encountered this is to use the IMDB ID number in the file folder name. In your case, it would be "\The 100 tt2661044\". It also might help to use the series name in the file name itself, such as "The 100 - S01E01 - Pilot.mp4". You can even add the IMDB ID in the file name itself if you have specific files that are incorrect.
mike.clayton999
Post Thu May 30, 2019 5:28 am
thanks, adding the IMDB reference to that one episode name resolved the issue.
Users browsing this forum: No registered users and 49 guests
