Qnap Serviio v2 Console problem with MS Edge
HarveyB
Post Tue Jun 11, 2019 12:07 pm
I have just installed Serviio V2 (Arm x41 version) on Qnap Device.
When using Microsoft Edge Browser.
If I open the console display, the welcome screen appears but SOME of the subsequent panels give problems panels failing to display properly:
- Selecting Status first displays a "... server does not seem to be running" message then an ill formatted panel
- Selecting Library-Shared Folders gives same result
- Selecting Library-Online Sources gives same result
- Rest of panels work fine
- MediaBrowser works fine.
The problems DO NOT occur when using Chrome Browser.
Serviio is running and working fine in all other aspects, it just seems to be a MS Edge "compatibility" problem.
I am running Windows 10 Pro on my PC.
I have attached some screen captures showing problem
Open Shared Folders.JPG (145.08 KiB) Viewed 5685 times
Open status Display.JPG (158.8 KiB) Viewed 5685 times
Open status.JPG (84.53 KiB) Viewed 5685 times
Post Tue Jun 11, 2019 2:31 pm
Re: Qnap Serviio v2 Console problem with MS Edge
That usually is caused by your browser cache retaining data from past usage. With changes made in each update, you get stuff like this. Clear your browser cache and try it again.
HarveyB
Post Tue Jun 11, 2019 2:51 pm
You are of course correct. I should have thought of that.
Thank you.
Users browsing this forum: Google [Bot] and 44 guests
