Asset UPnP not showing up on LG Smart TV
Haiban
Post Fri Jun 21, 2019 9:43 am
Basically as the heading states: Asset is not showing up in the TV's list of sources. My main DLNA server is Serviio, which shows up fine and has never presented a problem on this or any previous DLNA-capable TVs.
The service is running (and set to Automatic: Delayed Start), the running mode is set to Local Account (it doesn't show up when set to Service either) and apart from that I can't see what else I can change to try to make things work.
Both Asset and Serviio is running on my main (and only) computer, which has a cabled connection to my broadband router and to which the TV is also connected by cable.
Any ideas?
Post Fri Jun 21, 2019 12:57 pm
Re: Asset UPnP not showing up on LG Smart TV
I suspect you'd get better support from the Asset forum (https://forum.dbpoweramp.com/forumdispl ... f67911edc3). If Serviio is working fine, there's not much we can tell you here about a different product.
Return to LG
