Downgrade to 1.x Serviio version
tmtd
Post Mon Jun 24, 2019 1:50 pm
Due to the problems between ServiiGo and Serviio 2.0 i have to downgrade my Serviio server with 1.x version. How can i do this? I can simply execute on my Mac the installation file and he substitue? There is a problem with this procedure?
Thank you in advance
sake
Post Mon Jun 24, 2019 2:10 pm
Re: Downgrade to 1.x Serviio version
tmtd wrote:Due to the problems between ServiiGo and Serviio 2.0 i have to downgrade my Serviio server with 1.x version. How can i do this? I can simply execute on my Mac the installation file and he substitue? There is a problem with this procedure?
I am afraid that you would need to uninstall v2.0 and then re-install your 1.10/1.10.1 version. It happened to me and also to everyone else in the forums who wanted to downgrade :(
tmtd
Post Mon Jun 24, 2019 2:29 pm
I love Serviio but until Serviigo will be updated i have to use Serviio 1.x. I have to unistall and install? I can't only execute Serviio 1.x installer?
Post Mon Jun 24, 2019 2:53 pm
No, you can't installed an older version of Serviio over a newer version. There are usually changes to database structure or other working files with each update that you would likely not have a functional server by doing so. I believe you would find that very few applications will function correctly when you attempt to install an older version over a new one. Often the programs wouldn't even allow you to do so.
sake
Post Mon Jun 24, 2019 6:35 pm
Unfortunately you will have to uninstall the v2.0 one. I tried it and the whole app crashed. I was unable to start it and then realized that the uninstall was a must, unfortunately.
Sticking to v.1.10 for the time being.
Users browsing this forum: No registered users and 56 guests
