DTS files
kot
Post Sun Apr 03, 2011 4:33 pm
DTS files
Some files in my music collection are in DTS-format. For example:
Complete name                    : /green/mp3/Владимир Высоцкий - Песня О Земле/01. Он Не Вернулся Из Боя.dts
Format                           : Wave
File size                        : 33.2 MiB
Duration                         : 3mn 17s
Overall bit rate                 : 1 411.2 Kbps
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : LE / 14
Codec ID                         : 1
Codec ID/Hint                    : Microsoft
Duration                         : 3mn 17s
Bit rate                         : 1 411.2 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 44.1 KHz
Bit depth                        : 16 bits
Stream size                      : 33.2 MiB (100%)
Could these be auto-transcoded like the FLAC ones are already? Better yet, can such transcoding be entirely data-driven (via profiles or some such), so that each new transcoding-request does not require a code change? Thanks!
FreeBSD port of Serviio is now in the tree. Please, try using it and share your experience.
Post Sun Apr 03, 2011 4:40 pm
Re: DTS files
kot wrote:Some files in my music collection are in DTS-format. For example:
Format                           : Wave
Duration                         : 3mn 17s
Format                           : DTS
Codec ID                         : 1
Duration                         : 3mn 17s
Bit depth                        : 16 bits
Add a feature request to bitbucket for DTS audio support and then maybe ZIP can add it for 0.6, no it cant be data driven as its different for each renderer and support for a certain file type has to be added first before transcoding profile can be setup.
Post Sun Apr 03, 2011 4:59 pm
Re: DTS files
luna
Post Thu Apr 14, 2011 11:48 am
Re: DTS files
thanks for information...
Return to Feature requests
