Can't see files and have to keep selecting them after restar
ffstork
Post Sat Apr 02, 2011 7:57 pm
I have a samsung LN52B750 and Serviio running on Mac 10.6. I am trying to initially setup and configure to stream mostly videos. Currently when I go to my media menu on my TV I can see serviio as a device and select it, but my folders are all empty. I have only the folders that I have chosen to display. I have allowed plenty of time for the library to scan (multiple days.) I am unsure of what to try next. Another thing is after restarting computer the folders I have previously chosen to share are no longer listed and I have to select them again. Thanks in advance for the help, seems like wonderful software I just need to figure out how to use it properly.
(149.92 KiB) Downloaded 798 times
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
Post Sat Apr 02, 2011 8:39 pm
Re: Can't see files and have to keep selecting them after re
ffstork wrote:I have a samsung LN52B750 and Serviio running on Mac 10.6. I am trying to initially setup and configure to stream mostly videos. Currently when I go to my media menu on my TV I can see serviio as a device and select it, but my folders are all empty. I have only the folders that I have chosen to display. I have allowed plenty of time for the library to scan (multiple days.) I am unsure of what to try next. Another thing is after restarting computer the folders I have previously chosen to share are no longer listed and I have to select them again. Thanks in advance for the help, seems like wonderful software I just need to figure out how to use it properly.
log looks fine no errors, so im not sure other than some kind of permission issue and the DBs not be saved correctly.
ffstork
Post Sat Apr 02, 2011 8:50 pm
Thanks for the quick reply. I wound up uninstalling and reinstalling and that seemed to do the trick but now the TV says "Not Supported File Format." I thought the transcoding took care of that? I have the profile set properly (B-series). They are all H.264 AAC .m4v movies encoded using Handbrake.
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
ffstork
Post Sat Apr 02, 2011 9:20 pm
I would post the details of the file, but I can't figure out how. I looked at the howto section and I don't understand the instructions at all.
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
Post Sun Apr 03, 2011 9:43 am
ffstork
Post Sun Apr 03, 2011 3:47 pm
I'm on OSX, thanks though.
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
Post Sun Apr 03, 2011 3:54 pm
ffstork wrote:I'm on OSX, thanks though.
works exactly same on OSX but you have to run from the terminal program..
ffstork
Post Sun Apr 03, 2011 4:18 pm
I keep getting
"Adam-Ripleys-iMac:library Adam$ ffmpeg -i /users/adam/movies/role models.m4v
-bash: ffmpeg: command not found"
I have CD'd to the proper directory (I copied ffmpeg to the library folder to make it easier) but for some reason it is not finding the command.
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
Post Sun Apr 03, 2011 4:26 pm
ffmpeg.exe -i /users/adam/movies/role models.m4v
ffstork
Post Sun Apr 03, 2011 4:41 pm
Still same result. I am supposed to use .exe on OSX?
Samsung LN-52B750
XBOX 360
iMac OSX 10.6
Post Sun Apr 03, 2011 4:43 pm
ffstork wrote:Still same result. I am supposed to use .exe on OSX?
no use what ever extention the executable file have on osx i dnt remember what that is atm, make sure you have both the ffmpeg file and the video file in same folder too makes life alot easier..
