serviio 2 "can't connect to server" OSX Mojave.
bozobob1457
Post Thu Jul 04, 2019 8:54 pm
install serviio 2 on mac pro with Mojave. when started keeps getting "cannot connect to server.It doesn't seem to be running..." .Have uninstalled and deleted all serviio files,restarted and reinstalled .Nothing seems to help. What to do??
Post Thu Jul 04, 2019 11:53 pm
Re: serviio 2 "can't connect to server" OSX Mojave.
I'm unfamiliar with a Mac, but I believe we would need to see a Serviio log to see if it's actually running. Perhaps there's some sort of firewall that is blocking access, but first we need to know for sure if it's running or not. The log will show that.
GrandM1961
Post Wed Jul 31, 2019 12:47 am
bozobob1457 wrote:install serviio 2 on mac pro with Mojave. when started keeps getting "cannot connect to server.It doesn't seem to be running..." .Have uninstalled and deleted all serviio files,restarted and reinstalled .Nothing seems to help. What to do??
Are you sure you uninstalled everything from a previous version? I always use app cleaner
https://freemacsoft.net/appcleaner/ to make sure that everything gets uninstalled.
I have serviio installed on Mojave and on Catalina beta4, they both work but in Catalina there are a few issues. One of the biggest issue is i can’t select a external harddrive, but i guess Serviio 2 wasn’t tested on Catalina before. I would like to have the source and see where the bottleneck is.
Verzonden vanaf mijn iPhone met Tapatalk
Sony Bravia KDL-42W805A, iMac 27 inch late 2012, MacOS X 10.15 Beta 3
Users browsing this forum: No registered users and 75 guests
