Fri Dec 27, 2019 10:38 am by Paullik74
I've got a problem with my Panasonic TX-50CS630E and one of my MKV file.
Problem (mp4 video for better illustrativeness, its hard for me to explain it):
https://drive.google.com/file/d/1ep_iPdRuvT9ZbB8k6alUsdDG3VDsgc8C/view?usp=sharingServiio 2.0 settings:
- 2019-12-27.png (54.13 KiB) Viewed 23860 times
File mediaInfo:
- Code:
Hlavní
Unique ID : 22406822310707873275334624764382235876 (0x10DB65A219322F8452FFE79E59194CE4)
Complete name : E:\Videa 2\Filmy\Hobit\(1) Hobit - Neočekávaná cesta (2012)\(1) Hobit - Neočekávaná cesta (2012) [tt0903624].mkv
Format : Matroska
Format version : Version 4
File size : 36,2 GiB
Duration : 3 h 2 min
Overall bit rate : 28,4 Mb/s
Movie name : The Hobbit: An Unexpected Journey Extended
Encoded date : UTC 2019-12-26 09:59:52
Writing application : mkvmerge v41.0.0 ('Smarra') 64-bit
Writing library : libebml v1.3.9 + libmatroska v1.5.2
Cover : Yes
Attachments : cover.jpg
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Ano
Format settings, ReFrames : 2 frame
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 20,9 Mb/s
Width : 1 920pixely
Height : 1 080pixely
Display aspect ratio : 16:9
Frame rate : 23,976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.419
Stream size : 26,6 GiB (73%)
Language : English
Default : Ano
Forced : Ano
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate : 448 kb/s
Channel(s) : 6 kanály
Channel layout : L R C LFE Ls Rs
Sampling rate : 48,0 kHz
Frame rate : 31,250 FPS (1536 SPF)
Stream size : 585 MiB (2%)
Title : Surround 5.1
Language : Czech
Service kind : Complete Main
Default : Ano
Forced : Ano
Audio #2
Format : DTS XLL
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 5 339 kb/s
Channel(s) : 8 kanály
Channel layout : C L R LFE Lb Rb Lss Rss
Frame rate : 93,750 FPS (512 SPF)
Bit depth : 24 bits
Stream size : 6,81 GiB (19%)
Title : Surround 7.1
Language : English
Default : Ne
Forced : Ne
Audio #3
Format : DTS
Codec ID : A_DTS
Bit rate : 1 509 kb/s
Channel layout : C L R Ls Rs LFE
Bit depth : 24 bits
Stream size : 1,92 GiB (5%)
Language : English
Default : Ne
Forced : Ano
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 kanály
Stream size : 251 MiB (1%)
Title : Stereo
Language : English
Default : Ne
Forced : Ano
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 3 h 0 min
Bit rate : 519 b/s
Count of elements : 110
Stream size : 686 KiB (0%)
Language : Czech
Default : Ne
Forced : Ne
Text #2
Format : PGS
Duration : 3 h 1 min
Bit rate : 21,8 kb/s
Count of elements : 4400
Stream size : 28,3 MiB (0%)
Language : Czech
Default : Ne
Forced : Ne
Text #3
Format : PGS
Bit rate : 26,9 kb/s
Count of elements : 4952
Stream size : 34,9 MiB (0%)
Language : English
Default : Ne
Forced : Ne
Text #4
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Bit rate : 0 b/s
Count of elements : 55
Stream size : 1,28 KiB (0%)
Language : Czech
Default : Ano
Forced : Ano
Text #5
Format : UTF-8
Bit rate : 43 b/s
Count of elements : 2200
Stream size : 57,4 KiB (0%)
Language : Czech
Default : Ne
Forced : Ano
Menu
00:00:00.000 : en:Chapter 01
00:10:11.861 : en:Chapter 02
00:14:08.681 : en:Chapter 03
00:17:27.254 : en:Chapter 04
00:18:44.540 : en:Chapter 05
00:23:16.561 : en:Chapter 06
00:27:59.469 : en:Chapter 07
00:36:04.871 : en:Chapter 08
00:41:17.266 : en:Chapter 09
00:46:30.829 : en:Chapter 10
00:53:04.181 : en:Chapter 11
00:58:07.650 : en:Chapter 12
00:59:55.049 : en:Chapter 13
01:10:42.154 : en:Chapter 14
01:15:01.455 : en:Chapter 15
01:18:52.602 : en:Chapter 16
01:24:56.674 : en:Chapter 17
01:30:34.429 : en:Chapter 18
01:34:10.436 : en:Chapter 19
01:37:24.463 : en:Chapter 20
01:39:03.479 : en:Chapter 21
01:41:40.803 : en:Chapter 22
01:50:22.532 : en:Chapter 23
01:52:59.773 : en:Chapter 24
01:59:06.305 : en:Chapter 25
02:03:57.513 : en:Chapter 26
02:09:51.492 : en:Chapter 27
02:23:21.384 : en:Chapter 28
02:25:18.626 : en:Chapter 29
02:26:31.115 : en:Chapter 30
02:30:52.668 : en:Chapter 31
02:33:00.421 : en:Chapter 32
02:35:52.593 : en:Chapter 33
02:46:51.209 : en:Chapter 34
02:52:21.372 : en:Chapter 35
On PC and everywhere else its ok and video working correctly.
Any suggestions? I've tried community Viera 2015 profile but it's not working too.
