Alexa can’t find movie in library - RESOLVED
pollutionblues
Post Sat Jul 27, 2019 11:42 am
Hi everyone,
I’m new to Serviio and I want to use the Alexa Skill to play movies on my Sony Bravia KDL-55W829B TV. If I access the Serviio server manually using my TV remote I can play all my movies no problem but, if I say “Alexa ask Serviio to play [movie name] all I get is I am sorry, I didn’t find [movie name] in your Serviio library.
I have rebooted Serviio on my PC and rebooted my Amazon Echo but I still get the same response.
Thanks in advance for any help
Post Sat Jul 27, 2019 4:50 pm
Re: Alexa can’t find movie in library
Is it doing it for multiple titles, or just one or two? I know Alexa has issues with movie titles that have something besides just letters in the name. It requires a very specific pronunciation with those types of titles. What is an example title that it can't find?
pollutionblues
Post Sat Jul 27, 2019 5:05 pm
Thanks for the reply.
It’s happening with multiple titles, As an example. “Alexa, ask Serviio to play Friday” Alexa responds with: I’m sorry, I didn’t find Friday in your Serviio library. I’ve tried several different titles and I get the same response on all of them.
Post Sun Jul 28, 2019 2:02 am
But what is the exact title name? Is that it, Friday? I've never tried using my Echo to control Serviio, but perhaps there's a different way to phrase it. Have you seen the Alexa info page on the Serviio web site? https://www.serviio.org/alexa Perhaps it can give you some additional ideas.
pollutionblues
Post Sun Jul 28, 2019 8:02 am
Yes Friday is the title. The example video request commands on the Serviio support page is: “Ask Serviio to play Avatar” I have also tried this exact command and Alexa still gives the same response: I am sorry I didn’t find Avatar in your Serviio library.
I specifically purchased the pro version of Serviio to be able to control Serviio with my Echo so I’m hoping there is a solution to this.
pollutionblues
Post Sun Jul 28, 2019 8:40 am
I have just tried this with several different audio files and Alexa can’t find them in the Serviio library either.
Post Sun Jul 28, 2019 3:14 pm
Zip is going to need to comment on this. Since he is the developer, he knows exactly how it's supposed to work.
pollutionblues
Post Sun Jul 28, 2019 4:53 pm
No worries. Thank for trying to help
pollutionblues
Post Fri Aug 02, 2019 8:02 am
I have now tried installing Serviio on my Synology NAS but every time I use the command “Alexa, ask Serviio to play [movie name] on Sony TV” I get the response: “Sony TV is not active on your network, try re-naming your device in the Serviio console”
pollutionblues
Post Sat Aug 03, 2019 4:21 pm
I have uninstalled and reinstalled Serviio on my PC but Alexa still cant find any movies or music in my Serviio library.
Do the Serviio devs actually use the forums? The lack of support from Serviio staff is worrying, I wouldn't be as concerned if I was just using the free version but I purchased the pro version so I could use Alexa and there doesn't seem to be any support from Serviio.
pollutionblues
Post Tue Aug 06, 2019 11:20 am
I've enabled DEBUG logging and all movie files are showing as being added to the library. There does not seem to be anything in the logs relating to Alexa at all. If I use the command "Alexa, ask Serviio whats new" Alexa responds with "there are no movies in your Serviio library yet".
I'm starting to get pretty annoyed that I've spent £25 or so on the Pro version and there is no support at all from the Serviio devs and there doesn't seem to be any other way of getting support other than this forum.
pollutionblues
Post Fri Aug 09, 2019 4:11 pm
I have finally solved this issue. I had to tick the 'users with access' box on the library assign a user to the playback device.
Post Fri Aug 09, 2019 5:29 pm
Yes, the new Users settings have caught a few users off guard, and I forget about it when trying to help someone. Glad you found it!
Post Tue Aug 13, 2019 7:32 am
Re: Alexa can’t find movie in library - RESOLVED
Yes, another way to troubleshoot this is to try to search for the movie in MediaBrowser, using the same user that you use to connect with Alexa.
pollutionblues
Post Tue Aug 13, 2019 9:10 am
Thanks zip, good to know. The only other slight issue I have is that sometimes if I say Alexa, ask Serviio to play [movie title] Alexa doesn't seem to recognize the command at all and just makes a short sound. The workaround I have found is to say Alexa, open Serviio, then allow Alexa to go through the options and once she says what do you want to do now? ask to play a move title, this works with every movie I have tried so far.
Users browsing this forum: No registered users and 57 guests
