[SEVERAL PROBLEM] USB drive not recognized in Mac OS Catalin
Virgen Maria
Post Mon Aug 12, 2019 4:18 pm
USB drive not recognized in Mac OS Catalina
Hi, I have version 1.10, and everything works fine on my mac (with the Catalina operating system), but the external hard drives are not recognizable, why? With all the other DLNA servers I have no problem, they all recognize me external hard drives but no, what is the service? Any way that my external hard drives appear in VOLUMES ?. A greeting.
Post Tue Aug 13, 2019 9:54 am
Re: [SEVERAL PROBLEM] USB drive not recognized in Mac OS Cat
created a ticket and will look into it
https://bitbucket.org/xnejp03/serviio/i ... nal-drives
Virgen Maria
Post Tue Aug 13, 2019 10:14 am
zip wrote:created a ticket and will look into it
Thanks!! ;)
jeromeof
Post Sun Sep 01, 2019 10:25 pm
Serviio is not working for me on Catalina, I see an Sandbox error in the Console logs? Anyone know a workaround for this issue?
gio2000
Post Sat Sep 21, 2019 4:28 pm
Having the same issue , is there always a howto to solve ?
Regards
Post Mon Sep 23, 2019 7:30 pm
Which one? USB drive or console error? In any case, some more details like screen shots and logs would help.
alexozr
Post Sun Sep 29, 2019 5:53 am
Hello!
Same problem for me.
Serviio does not recognize usb-drives:
Screenshot 2019-09-29 at 08.46.58.png (238 KiB) Viewed 20565 times
Screenshot 2019-09-29 at 08.44.45.png (206.59 KiB) Viewed 20565 times
That will be great to fix this annoying bug.
Thanks in advance :)
alexozr
Post Sun Sep 29, 2019 7:49 am
Actually I've found a solution - just grant full disk access to java process in macOs settings:
Screenshot 2019-09-29 at 10.47.27.png (177.21 KiB) Viewed 20564 times
Anyway, It will be great if Serviio app ask a permission when starts first time :)
Post Sun Sep 29, 2019 11:08 am
Great, thanks for posting this. I'm not sure if it's a problem of the os beta that might be fixed later. So for now this workaround is fine and I will look into it again when the full release is out and the problem persists.
A1D
Post Wed Oct 09, 2019 3:01 pm
alexozr wrote:Actually I've found a solution - just grant full disk access to java process in macOs settings:
@alexozr
Thanks for that.
I want to upgrade today and trying to "put myself away from the rainy day".
I have opened the preferences Full Disk Access in Mojave and didn't find any process called "java".
I have found "java" in system processes in Activity Monitor, but did found how to put it into the Full Disk Access.
How did you do so?
Thanks!
Vi veri universum virus vici
Galaf
Post Thu Oct 10, 2019 12:51 pm
Grant full disk access to Java worked for me.
Both for USB drives AND the Downloads directory (as per viewtopic.php?f=5&t=25608&p=124214#p124214)
Post Thu Oct 10, 2019 9:37 pm
I've added a FAQ for this: https://serviio.org/index.php?option=co ... &id=21#q21
Looks like the Full Disk Ac cess is the only solution, because the Serviio server runs as a background process (and not an app), so that the OS cannot ask to give the less restrictive permissions.
In any case, this gives the access to the Serviio java binary, not your system java (so at least a bit less open then first thought)
JunJun
Post Tue Jul 08, 2025 10:59 am
Thank you !!!!
I just had this issue and thanks to your post I got to solve it !!
