Sony BDP-Sx100 (2013) do not play online sources
alfredogoncalvejr
Post Wed Aug 14, 2019 4:26 am
My BluRay (Sony BDP-Sx70/SMP-N100 (2010)) plays normally files recorded in the service folder, but do not play online sources. Does anyone have any tips?
SERVIO.LOG:
java.io.IOException: Read end dead
   at java.io.PipedInputStream.checkStateForReceive(PipedInputStream.java:262)
   at java.io.PipedInputStream.receive(PipedInputStream.java:226)
   at java.io.PipedOutputStream.write(PipedOutputStream.java:149)
   at org.serviio.external.io.PipedOutputStreamMultiplexer$3.call(PipedOutputStreamMultiplexer.java:87)
   at org.serviio.external.io.PipedOutputStreamMultiplexer$MultiplexCaller.multiplex(PipedOutputStreamMultiplexer.java:119)
   at org.serviio.external.io.PipedOutputStreamMultiplexer.write(PipedOutputStreamMultiplexer.java:89)
   at org.serviio.external.io.PipedOutputBytesReader.processOutput(PipedOutputBytesReader.java:58)
   at org.serviio.external.io.OutputReader.run(OutputReader.java:47)
2019-08-14 02:06:06,388 DEBUG [PipedOutputStreamMultiplexer] Removing client from multiplexer: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:06:06,401 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true": AVC_TS_MP_HD_AAC_MULT5_ISO
2019-08-14 02:06:06,401 DEBUG [VideoDeliveryEngine] Delivering file 'https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true' using transcoding (profile: bdp2013 > quality: ORIGINAL > OnlineTranscoding > [MPEG2TS] > matcher: 1)
2019-08-14 02:06:06,401 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2019-08-14 02:06:06,401 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2019-08-14 02:06:06,401 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Wed, 14 Aug 2019 05:06:06 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/2.0,transferMode.dlna.org: Streaming]]
2019-08-14 02:06:08,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:13,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:16,464 DEBUG [SearchManager] Committing search index
2019-08-14 02:06:18,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:23,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:28,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:33,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:34,523 DEBUG [RendererSearchSender] Searching for Renderer devices
2019-08-14 02:06:34,523 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:06:34,523 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2019-08-14 02:06:34,523 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.103:61752s
2019-08-14 02:06:34,524 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:06:34,524 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.103:61752s
2019-08-14 02:06:35,424 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:06:35,424 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:06:35,424 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:06:35,430 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:36,700 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-08-14 02:06:36,700 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-08-14 02:06:36,700 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:06:37,061 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:06:37,061 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:06:37,061 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:06:37,066 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:37,349 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:06:37,349 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:06:37,349 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:06:37,353 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:38,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:40,523 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2019-08-14 02:06:43,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:46,465 DEBUG [SearchManager] Committing search index
2019-08-14 02:06:48,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:53,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:57,961 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:06:57,962 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d5d83c03-42e3-377d-afa7-8f5cd9997f2a
2019-08-14 02:06:58,569 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51507: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,569 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,569 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,570 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.102 (headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";])
2019-08-14 02:06:58,570 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,570 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,570 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]
2019-08-14 02:06:58,571 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,573 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,583 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51508: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,584 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,584 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,584 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-08-14 02:06:58,586 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,595 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51509: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,595 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,596 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,596 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-08-14 02:06:58,599 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,611 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51510: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-08-14 02:06:58,612 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,612 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,612 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102
2019-08-14 02:06:58,613 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,613 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:06:58,654 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,659 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51511: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-08-14 02:06:58,659 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,659 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,659 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.102
2019-08-14 02:06:58,660 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,660 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,701 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,707 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,774 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51512: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,774 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,775 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,775 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.102 (headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";])
2019-08-14 02:06:58,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,775 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]
2019-08-14 02:06:58,776 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,776 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,776 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,784 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51513: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,784 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,784 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,786 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-08-14 02:06:58,786 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,793 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51514: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,793 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,794 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,794 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-08-14 02:06:58,794 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,805 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51515: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-08-14 02:06:58,805 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,805 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,806 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102
2019-08-14 02:06:58,806 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,806 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,848 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,851 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51516: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-08-14 02:06:58,852 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,852 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,852 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.102
2019-08-14 02:06:58,853 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,853 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,894 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,897 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:58,965 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51517: GET /deviceDescription/d5d83c03-42e3-377d-afa7-8f5cd9997f2a HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,965 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,965 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,966 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d5d83c03-42e3-377d-afa7-8f5cd9997f2a from 192.168.1.102 (headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";])
2019-08-14 02:06:58,966 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,966 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,966 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:56 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]
2019-08-14 02:06:58,967 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,967 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:58,977 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51518: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:57 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,977 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,977 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,978 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2019-08-14 02:06:58,981 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:58,989 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51519: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.1.103:8895,Date: Wed, 14 Aug 2019 05:06:57 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";]]
2019-08-14 02:06:58,989 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:58,989 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:58,989 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2019-08-14 02:06:58,989 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2019-08-14 02:06:59,002 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51520: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2019-08-14 02:06:59,002 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,002 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,002 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102
2019-08-14 02:06:59,003 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,003 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,045 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:59,048 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51521: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2019-08-14 02:06:59,048 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,049 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,049 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.102
2019-08-14 02:06:59,049 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:06:59,050 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:06:59,091 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony BDP-Sx100 (2013)'
2019-08-14 02:06:59,093 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:06:59,775 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:40 (advertisement duration is 1800 sec.)
2019-08-14 02:07:02,498 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:02,498 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:02,512 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:02,737 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:02,737 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:02,742 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:03,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:06,404 DEBUG [TimeoutStreamDelegator] Closing piped input stream and closing related feeder process
2019-08-14 02:07:06,404 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-128,5,main]
2019-08-14 02:07:06,407 DEBUG [ProcessUtils] Killing the Windows process: 10920
2019-08-14 02:07:06,417 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2019-08-14 02:07:06,417 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-f53802657f8243a7d86a6910b7b61720.stf' of client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,423 DEBUG [WebServer] I/O error: Pipe broken
2019-08-14 02:07:08,426 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51532: GET /resource/1000000810001992/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [User-Agent: UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.103:8895,Accept: */*,X-AV-Physical-Unit-Info: pa="BLU-RAY HOME THEATRE SYSTEM",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BLU-RAY HOME THEATRE SYSTEM"; mv="2.0",getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming]]
2019-08-14 02:07:08,426 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:08,426 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:08,427 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:08,427 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:08,427 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,427 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000810001992 and type 'MEDIA_ITEM' received
2019-08-14 02:07:08,428 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000810001992 (online)
2019-08-14 02:07:08,428 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:07:08,428 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000810001992, format AVC_TS_MP_HD_AAC_MULT5_ISO and profile Sony BDP-Sx100 (2013)
2019-08-14 02:07:08,428 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true
2019-08-14 02:07:08,428 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true": AVC_TS_MP_HD_AAC_MULT5_ISO
2019-08-14 02:07:08,428 DEBUG [VideoDeliveryEngine] Delivering item '1000000810001992' for client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,429 DEBUG [AbstractAVTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:08,429 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true
2019-08-14 02:07:08,429 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe -fflags +genpts -threads 0 -analyzeduration 10000000 -i https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true -y -threads 0 -c:v copy -bsf:v h264_mp4toannexb -c:a:0 copy -map 0:0 -map 0:1 -sn -f mpegts pipe:
2019-08-14 02:07:08,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:08,929 DEBUG [StreamBasedTranscodingDeliveryStrategy] Adding client to stream multiplexer: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:07:11,933 DEBUG [StreamBasedTranscodingDeliveryStrategy] Already multiplexing stream output to client: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:07:11,933 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true": AVC_TS_MP_HD_AAC_MULT5_ISO
2019-08-14 02:07:11,933 DEBUG [VideoDeliveryEngine] Delivering file 'https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true' using transcoding (profile: bdp2013 > quality: ORIGINAL > OnlineTranscoding > [MPEG2TS] > matcher: 1)
2019-08-14 02:07:11,933 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2019-08-14 02:07:11,933 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2019-08-14 02:07:11,933 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Cache-control: no-cache,Connection: close,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,Date: Wed, 14 Aug 2019 05:07:11 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows_10 UPnP/1.0 DLNADOC/1.50 Serviio/2.0,transferMode.dlna.org: Streaming]]
2019-08-14 02:07:11,935 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2019-08-14 02:07:11,935 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2019-08-14 02:07:12,936 DEBUG [PipedOutputStreamMultiplexer] Caught exception: Read end dead
2019-08-14 02:07:12,936 DEBUG [PipedOutputStreamMultiplexer] Removing client from multiplexer: Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:07:13,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:16,467 DEBUG [SearchManager] Committing search index
2019-08-14 02:07:16,828 DEBUG [ServiioHttpService] Incoming request from /192.168.1.102:51533: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BD/DVD HOME THEATRE SYSTEM";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BD/DVD HOME THEATRE SYSTEM"; mv="2.0";,Host: 192.168.1.103:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 598,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2019-08-14 02:07:16,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:16,829 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:16,829 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.102
2019-08-14 02:07:16,829 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2019-08-14 02:07:16,830 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:16,872 DEBUG [ContentDirectory] Browse() called for renderer BDV (profile bdp2013) with parameters: objectID = V_OF, browseFlag = BrowseDirectChildren, filter = av:mediaClass,dc:title,dc:date,@childCount,upnp:class,res,res@resolution,res@size,res@protocolInfo,res@duration,res@bitrate,av:containerClass,res@dlna:ifoFileURI, startIndex = 1, count = 10, sortCriteria =
2019-08-14 02:07:16,872 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,873 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,874 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,874 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO [alfredo]
2019-08-14 02:07:16,876 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2019-08-14 02:07:18,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:23,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:28,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:31,937 DEBUG [TimeoutStreamDelegator] Closing piped input stream and closing related feeder process
2019-08-14 02:07:31,937 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-148,5,main]
2019-08-14 02:07:31,937 DEBUG [ProcessUtils] Killing the Windows process: 7628
2019-08-14 02:07:31,948 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2019-08-14 02:07:31,948 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-f53802657f8243a7d86a6910b7b61720.stf' of client 'Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV'
2019-08-14 02:07:33,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:34,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.103:56073s
2019-08-14 02:07:34,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dslforum-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:34,669 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:34,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:34,670 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.103:56073
2019-08-14 02:07:35,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.103:56073s
2019-08-14 02:07:35,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:35,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dslforum-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:35,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:35,671 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.103:56073
2019-08-14 02:07:36,674 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.103:56073s
2019-08-14 02:07:36,674 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:36,674 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dslforum-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:36,674 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.103:56073s
2019-08-14 02:07:36,675 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.103:56073
2019-08-14 02:07:36,701 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-08-14 02:07:36,701 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-08-14 02:07:36,701 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:07:38,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:40,571 DEBUG [RendererSearchSender] Searching for Renderer devices
2019-08-14 02:07:40,572 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:07:40,572 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2019-08-14 02:07:40,572 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.103:49258s
2019-08-14 02:07:40,572 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:07:41,262 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:07:41,262 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:41,262 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:41,267 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:43,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:43,854 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:07:43,854 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:43,854 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:43,858 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:43,972 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:07:43,972 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:07:43,972 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:07:43,977 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:07:46,468 DEBUG [SearchManager] Committing search index
2019-08-14 02:07:46,572 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2019-08-14 02:07:48,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:53,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:07:58,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:02,391 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:02,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:02,496 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:02,496 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:02,503 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:02,731 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:02,731 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:02,736 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:03,392 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:03,392 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:03,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:04,394 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:04,394 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:05,395 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.1.103:62218s
2019-08-14 02:08:05,395 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.103
2019-08-14 02:08:08,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:13,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:16,470 DEBUG [SearchManager] Committing search index
2019-08-14 02:08:18,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:23,627 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:28,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:33,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:36,361 DEBUG [PlaylistDAOImpl] Reading all Playlists
2019-08-14 02:08:36,702 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2019-08-14 02:08:36,702 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2019-08-14 02:08:36,702 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 81)
2019-08-14 02:08:38,630 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:43,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:45,841 DEBUG [ActionsServerResource] Action with name 'stopServer' was requested
2019-08-14 02:08:45,841 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2019-08-14 02:08:45,841 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: D:\Vídeos\Temp-Serviio\Serviio
2019-08-14 02:08:45,841 DEBUG [DiscoveryManager] UPNP device d5d83c03-42e3-377d-afa7-8f5cd9997f2a (192.168.1.103) is unavailable
2019-08-14 02:08:45,841 DEBUG [WebServer] Socket closed
2019-08-14 02:08:45,841 DEBUG [WebServer] Marking the web server for exit
2019-08-14 02:08:45,841 INFO  [WebServer] WebServer shutting down
2019-08-14 02:08:45,841 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2019-08-14 02:08:45,841 DEBUG [DiscoverySSDPMessageListener] Socket closed: socket closed
2019-08-14 02:08:45,841 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2019-08-14 02:08:45,841 INFO  [EventDispatcher] Leaving EventDispatcher
2019-08-14 02:08:45,841 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2019-08-14 02:08:45,891 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:08:46,358 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2019-08-14 02:08:46,472 DEBUG [SearchManager] Committing search index
2019-08-14 02:08:46,618 DEBUG [RendererSearchSender] Searching for Renderer devices
2019-08-14 02:08:46,618 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth3 (Intel(R) Ethernet Connection (7) I219-V) and address 192.168.1.103, timeout = 0
2019-08-14 02:08:46,618 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2019-08-14 02:08:47,834 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:08:47,834 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:47,834 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:47,838 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:48,071 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:08:48,071 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:48,071 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:48,076 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:48,505 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.1.102:52323/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2019-08-14 02:08:48,505 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 00000000-0000-1010-8000-3c07711455c1 from address 192.168.1.102
2019-08-14 02:08:48,505 DEBUG [RendererManager] Retrieve device description from http://192.168.1.102:52323/dmr.xml
2019-08-14 02:08:48,510 DEBUG [UserDAOImpl] Reading a User (id = 1)
2019-08-14 02:08:48,628 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:52,618 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2019-08-14 02:08:53,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:58,425 DEBUG [PipeManager] Stopped PipeProcessingConsumer
2019-08-14 02:08:58,526 DEBUG [PipeManager] Stopped PipeProcessingConsumer
2019-08-14 02:08:58,526 INFO  [LibraryOneTimeScanner] Interrupting library scan
2019-08-14 02:08:58,526 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2019-08-14 02:08:58,526 INFO  [LibraryDeltaScanner] Stopping the library delta scan
2019-08-14 02:08:58,526 DEBUG [FileDeltaPoller] Stopping FileDeltaPoller
2019-08-14 02:08:58,528 DEBUG [FileDeltaWatcher] Stopping FileDeltaWatcher
2019-08-14 02:08:58,528 INFO  [PlaylistMaintainerWorker] Finished looking for playlist changes
2019-08-14 02:08:58,629 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2019-08-14 02:08:58,629 INFO  [FeedUpdaterWorker] Finished looking for online resources information
2019-08-14 02:08:58,629 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2019-08-14 02:08:58,729 INFO  [PluginCompilerThread] Finished looking for plugins
2019-08-14 02:08:58,832 INFO  [SearchIndexer] Closing search index writer
2019-08-14 02:08:58,834 INFO  [SearchIndexer] Closing search index writer
2019-08-14 02:08:58,855 INFO  [PlaybackEventsManager] Playback of media item 1000000810001992 (https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true [https://verydatacenterpls.verystream.net/stream/ZVR279yLBjp/i0BaXst5b0TE4iCB/xvKNgfza1Qt6bFJw4XQKOFD5LVx9N5I6wSJnKRDixpGgBiyzVyhsV-nEQEryInj1nmk7J0TAm_T7jbfli61A4n6HG5v9s65rrHigYYoMsuZajfnkDrWHc4fShSaQ5hTPf9pUOCXDD5gSItUV6wUeU6oajSR4a-2y_BP8psfuLn5dXluhUKfmwD0rh9fqxTj2HLrFY7RUBJjJ0-MT1dNMgMGqpBZpPsfCkVUI_lu5tJE16Y00TXUpd1eAHappW1yg1h3Aa3-hmmFz2r04s_sZbvgvooNzKdk6rS1kAQz7SYEy35QLNNb0bmi6M9wiexCVtJM4gkSuzhpZfyBi1kKDZA0vYCPWpEROORBZt6Wyty5ocmL5Vf817PYXHy2L-_jrgxEf5_0j4053g_PWAd-V3ApTdEZm5PSI-wFmodxOn5TxMcDC1TLlXrVE8nTjI_Dm/Coyote.Lake.2019.720p.LEGFIXA.mp4?mime=true]) has stopped at 0% on Identifier=192.168.1.102, Profile=Sony BDP-Sx100 (2013), Name=BDV
2019-08-14 02:08:58,855 INFO  [RendererSearchSender] Stopping Renderer searcher process
2019-08-14 02:08:58,856 INFO  [DatabaseManager] Shutting down database
2019-08-14 02:08:58,856 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2019-08-14 02:08:58,887 WARN  [DatabaseManager] DB shutdown returned: Derby system shutdown.
2019-08-14 02:08:58,888 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2019-08-14 02:08:58,888 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: D:\Vídeos\Temp-Serviio\Serviio
Post Thu Aug 15, 2019 1:18 am
Re: Sony BDP-Sx100 (2013) do not play online sources
I added the code tags to your log data to streamline the post. The data is still all there.
Please confirm exactly what model Sony player you have. Have you tried any other Sony profiles? Your title says Sx100, but your message says Sx70. Those are two quite different profiles.
Can you provide an example of an online source you are attempting to play?
