HOWTO stream 3d movie from PC to my TV?
dawid79
Post Tue Aug 13, 2019 3:43 pm
I have several 3d movies on my PC, I wanted to watch them on my TV with my 3D glasses (the one with blue and red glasses), and instead of 3D picture my screen is split into two, normally on my PC I was using VLC to play such movies with option "anaglyph 3d" on. How can I do it with serviio?
thanks.
Post Tue Aug 13, 2019 9:37 pm
Re: HOWTO stream 3d movie from PC to my TV?
I'm going to make a guess, as I don't have any 3D titles. As long as the video doesn't require transcoding, the 3D information should be intact in the stream. I'm unaware of anything required to stream 3D video, just that the display has to support it. But if the video is being transcoded, then it's likely the 3D encoding will be lost. Again, just my thoughts on what should work.
dawid79
Post Sat Aug 17, 2019 12:15 am
no it does not work like that, with anaglyph 3D you have to pick option in your video player, otherwise it will show you two pictures side by side.
Post Sat Aug 17, 2019 12:22 am
So you can't pick that option on the TV menu while streaming from Serviio? Because your TV is the video player, not Serviio. While I do have a 3D capable TV, I have to 3D titles so can't test anything here.
