Synology Diskstation Cant Activate HD Thumbnails
Post Sun Aug 25, 2019 9:52 pm
Re: Synology Diskstation Cant Activate HD Thumbnails
That should work, as there's no special configuration that I am aware of for a NAS device. The ThumbnailsResolution switch can be within a device profile, as well as within Profile #1, so if the profile you're using has that set to DLNA it would override the setting from Profile #1.
I don't use AllowedImageResolutions on my servers. Instead, I edit the ServiioService.exe.vmoptions file located in the \bin folder of the Serviio installation with the following line:
-Dserviio.hdThumbnailResolution=1000
I'm pretty sure that file exists on a NAS install as well. Also, just re-scanning the library won't refresh the thumbnails. Go to the Metadata tab on the Serviio console and click "Rescan Video Metadata". That will refresh the thumbnails.
Paul C
Post Mon Aug 26, 2019 1:04 pm
This topic has been raised several times before see viewtopic.php?f=4&t=17870&p=120772&hilit=artwork+hd#p120772
I have brilliant artwork.
As indicated I do not think it has anything to do with your NAS.
Are you referring to audio or video or both?
If you do not already have a user-profiles.xml file in "Program Files/Serviio/config" directory I have attached one (Generic HD profile) that you can try. That gives you 320x320 by default instead of 160x160) - that's the first step.
Then set the higher resolution you want i.e. 600 or 1000 as you require. e.g. -Dserviio.hdThumbnailResolution=600 in the ServiioService.exe.vmoptions file.
Regenerating the images some times seems to be a problem - experiment by adding a new entry and have patience.
(Note-if you are not using the generic profile for your device you will need to change or setup an alternative HD capable profile).
I have made a request for improvements to this process, particularly as some of the changes are lost on an upgrade. Infuriating. see viewtopic.php?f=3&t=25218#p120942
Also configuration not simple for people not comfortable messing in the innards of Serviio.
user-profiles.xml
user-profiles.xml file with Generic HD profile
(14.97 KiB) Downloaded 580 times
Post Sat Oct 12, 2019 3:55 pm
dovedescent7 wrote:May i ask, why would the devs at Serviio name something with an "exe" as in "ServiioService.exe.vmoptions" for a synology nas running linux? Are they purposely trying to confuse people? Linux doesn't use EXE extensions!
That I can't answer. Zip is the one and only developer of Serviio. Since it's not really an exe file, I agree that is seems out of place on a non-Windows device. But it of course doesn't hurt anything being there, either. :D
Post Sun Oct 13, 2019 12:46 pm
for the NAS / Linux, it'd be in the serviio.sh file.
I will try to make this easier in the future versions.
Users browsing this forum: Baidu [Spider], Google [Bot] and 23 guests
