V2 Remote User
DaFerociousBeast
Post Tue Sep 17, 2019 12:48 am
V2 Remote User
Does Serviio 2 support remote users through web browser?
I've read that users are tied to devices, how would serviio recognize a
device over the internet, especially cellular? Just wonderering if Media Browser
supports usernames?
Post Tue Sep 17, 2019 12:46 pm
Re: V2 Remote User
Yes, Serviio offers web browser access with the Pro version. MediaBrowser now supports user logins, so user access can be controlled. Using DLNA on your internal network it is possible to tie devices to user accounts, but there are no devices when using MediaBrowser.
DaFerociousBeast
Post Wed Sep 18, 2019 3:17 am
Re: V2 Remote User
Thank You. So this allows user access to specific folders/files?
Post Wed Sep 18, 2019 1:50 pm
Re: V2 Remote User
Yep :D
Folder level, not file. But you can assign a MPAA rating limit to a user, so if you wanted to block all R rated videos you can do that as well.
DaFerociousBeast
Post Wed Sep 18, 2019 4:17 pm
Re: V2 Remote User
Ok. Thanks.
Post Wed Sep 18, 2019 9:05 pm
Re: V2 Remote User
works per shared folder
Users browsing this forum: Google [Bot] and 36 guests
