Can v1 & v2 be installed together?
DaFerociousBeast
Post Wed Sep 18, 2019 4:16 pm
I want to test v2, but don't want to uninstall my v1 pro edition.
Can both program versions run simultaneously?
I like the user access feature and want to test, but don't want to uninstall v1.
Post Wed Sep 18, 2019 5:33 pm
Re: Can v1 & v2 be installed together?
I don't believe so without some higher level file editing skills. They would both attempt to use the same ports, which doesn't work. I have read of editing one of the jar files to alter the internal port that's used, and of course it would have to be installed in separate folders. If you have another computer available, you could always install it temporarily on that one.
DaFerociousBeast
Post Wed Sep 18, 2019 9:24 pm
Ok
Users browsing this forum: Baidu [Spider] and 57 guests
