Mediabrowser doesn't show media content.
hina
Post Thu Sep 19, 2019 6:51 am
Hi
I use Serviio 2.0 on CentOS 7. I installed at yesterday. TVs have access to all media content, and show them all. But MediaBrowser doesn't show nothing, only the basic categories. If I go into folders, or last added, or any one of them, is empty.
how can i solve the problem?
mihai.aka
Post Fri Sep 20, 2019 7:27 am
Re: Mediabrowser doesn't show media content.
Hello!
+1 here with the same issue.
Running Serviio 2.0 on Raspbian (Pi3). TV and PCs/Smartphones all works well via DLNA (thank you for that).
The MediaBrowser shows the categories/folders with their thumbnails, but not the video files within.
Not really able to get the "pro" experience in the trial days.
Something to change from the user's side?
mihai.aka
Post Sun Sep 22, 2019 1:59 pm
Dear hina,
While reading viewtopic.php?f=5&t=25513 i noticed the user being brought in discussion.
After ticking the box from the attached picture, the files became visible for me. Please check from your side.
later edit: i've removed the picture as it was showing my ddns as well :))
bematft
Post Sun Sep 22, 2019 3:35 pm
mihai.aka wrote:Dear hina,
Yes work for me! Thanks! Serviio 2.0 Synology
hina
Post Tue Sep 24, 2019 7:06 am
Hi
Thank you the information. When I added the folders, the user did not exist yet. I checked in the checkbox before the username and everything working fine.
YGDPptmRT
Post Mon Sep 30, 2019 7:05 pm
Hello, thanks for the tip! Had exactly the same problem and the suggestion worked like a charm. :D
Users browsing this forum: No registered users and 60 guests
