WTV Sub-title
Padsu
Post Sun Sep 22, 2019 4:49 pm
WTV Sub-title
Hello, is it possible to display the subtitles of a wtv file sent by Serviio on a Samsung TV?
Despite my research I have not found yet.
cordially
Post Sun Sep 22, 2019 10:29 pm
Re: WTV Sub-title
Padsu wrote:Hello, is it possible to display the subtitles of a wtv file sent by Serviio on a Samsung TV?
cordially
No, unfortunately. The TV doesn't support the WTV container, so it requires transcoding. That strips out the subtitles from the stream. I'm also not certain that the TV actually supports EIA-608 subtitles via DLNA. I just tried it with my Samsung NU7100 with recorded TV in a TS container, and no captions were displayed. However, with the TS container a Roku player will display the captions.
So your best bet would be to remux your videos into a TS container. I use VideoReDo, which also allows fast and easy editing to remove commercials and the stuff before and after the show itself. A little pricey, but really easy to use. Just using FFMPEG from the command line might also work, but I've never tried it.
Users browsing this forum: No registered users and 57 guests
