Number & Filter
kingoffools13
Post Thu Feb 24, 2011 7:19 pm
Number & Filter
Hopefully this is an easily added feature :)
I guess these are two separate requests, but I'd like the ability to set any folder to sort by date modified or alphabetically (ascending and descending) and the other request ... and really more important at this point to be able to set the number of "recently added" files that show up in the recently added section. Currently the number listed is about 10 i think but it would be nice if there was a little box where i could set this as high as i wanted (i'd like at least 50-100 of the most recent files to show up in last added order).
K
O
f
Post Thu Feb 24, 2011 8:23 pm
Re: Number & Filter
This will be avalible soon on the smasung devices once ZIP manages to get the sub menu to work and i have no doubt he will manage it :) then maybe he can adapt that type of menu for other devices so they can benefit from a menu rather than lots of sort folders.
Post Fri Feb 25, 2011 9:45 am
Re: Number & Filter
not sure what you're talking about cerberus ;-) Serviio controls how many entries are included in last added, last viewed categories.
Post Fri Feb 25, 2011 9:46 am
Re: Number & Filter
That sub menu that appears on teh smasung devices when u press (D) on remote that you were working on getting working :)
kingoffools13
Post Mon Apr 04, 2011 4:36 pm
Re: Number & Filter
so just checking any update on this? is it possible? how hard or long would it be to implement?
K
O
f
Post Mon Apr 04, 2011 5:26 pm
Re: Number & Filter
kingoffools13 wrote:so just checking any update on this? is it possible? how hard or long would it be to implement?
K
O
f
samsung support has massively improved but the menu i was talking about has not yet been implemented.
Return to Feature requests
