Metadata help
dsmithar19
Post Fri Oct 04, 2019 8:41 pm
Metadata help
I've downloaded a few movies and got them loaded into Serviio. One of them has the wrong metaData displaying. I don't want to rename the file as that will break the torrent.
I've tried setting up a movie.nfo as well as a <actualFileName>.nfo and re-scanning metadata but what's displayed does not get updated. I change the meta source to be XBMC .nfo file and re-scanned and still nothing.
file contents wrote:<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<movie>
<uniqueid type="imdb" default="true">tt0096874</uniqueid>
<title>test</title>
<originaltitle>test</originaltitle>
<outline>outline</outline>
<plot>plot</plot>
</movie>
There are only a few broken so I don't mind setting up file to fix'em.
Post Sun Oct 06, 2019 3:50 am
Re: Metadata help
Did you try moving the file out of the library and back in - that will force it to load new metadata.
Most torent clients allow you to rename the file from within the client. This will then maintain the integrity of the torrent.
Users browsing this forum: Baidu [Spider] and 110 guests
