Has anyone ever installed to an Icy Box NAS?
bork
Post Sat Jan 29, 2011 11:00 am
More specifically, the IcyBox NAS-4220
Using Google I can't find any references to anyone doing this and there may well be a good reason why this is so as it is/was a pretty popular NAS.
Just wondering really - I'm not a Linux expert by any means but can muddle through but don't want to waste my time if this isn't possible.
Post Sun Jan 30, 2011 1:39 pm
Re: Has anyone ever installed to an Icy Box NAS?
if its running linux theres no reason why it shouldnt work but without having one infront of me i could tell you how to set that up...
bork
Post Sun Jan 30, 2011 6:39 pm
I might have a go at it - if I get it to work I'll post instructions.
If you install on a Linux server, how do you access the console, or do you have to do the things that would normally be done via the console using config files?
Post Sun Jan 30, 2011 8:21 pm
Setup the console to connect remotely - see FAQ.
wirewolf86
Post Mon Apr 04, 2011 9:23 pm
Did you get this working?
Im interesting in doing this on my ICY-BOX :)
Post Tue Apr 05, 2011 9:43 am
wirewolf86 wrote:Did you get this working?
This is a very old post so i would guess th OP had no luck in making it work but your welcoem to try and if you have any problem just post and the team here should be able to help you out. :)
