first use-server error
appleman59
Post Sat Oct 19, 2019 4:16 pm
i have installed on imac and run software but all i get is a window saying.. "Cannot connect to server, it dosent seem to be running".
The instructions say check this address http://localhost:23423/console. that came up with "This site can’t be reachedlocalhost refused to connect."
I also turned off my firewall but that made no difference.
Bit of a shame that its fallen at the first hurdle and there is no other means of help?
Anyone got a suggestion that isn't overly technical please?
Many thanks.
Post Sat Oct 19, 2019 4:49 pm
Re: first use-server error
Please upload your Serviio log here. That appears to show that Serviio isn't starting, and the log is the only way we can find out why. Sometimes the database doesn't get set up correctly on install, and that could cause a non-start. Can't say why it happens, but usually a removal and reinstall resolves the issue.
appleman59
Post Sun Oct 20, 2019 4:02 pm
found the attached log file under the system applications folder. Hope thats the right one?
(41.28 KiB) Downloaded 514 times
Post Sun Oct 20, 2019 7:23 pm
Yes, that's the correct log. Looking at it, there is a failure to open the database. In addition, it says this:
Invalid checksum on Page Page(1,Container(0, 2017)), expected=3,842,662,242, on-disk version=92,673,728
Checksum can either mean memory (RAM) or a drive issue. The first thing I would do is to uninstall/remove Serviio from the computer, reboot, then try installing again. If it again fails, your hard drive appears to have an error. What operating system are you using, and how old is the computer?
Users browsing this forum: Google [Bot] and 45 guests
