Synology DS211+ Can´t switch to "keep original"
boko
Post Fri Mar 25, 2011 6:02 pm
Hello from Darmstadt Germany.
Thanks´ to Patters for his guide to install Serviio on my Synology NAS, I finaly get Serviio running.
I used it together with my LG BD 390 over WLAN. I have switch to Gbit cable to get HD streams running, SD are fine over WLAN.
Here now my problem, I can´t switch to "Keep original" at the transcoding tab.
After I click save, it jumped back to "Downmix to stereo".
All other setting can be saved.
Here are the output from ffmpeg:
~$ ffmpeg
built on Mar 15 2011 23:08:50 with gcc 4.2.3
configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Use -h to get full help or, even better, run 'man ffmpeg'
Any idea?
Thanks boko
Post Fri Mar 25, 2011 6:58 pm
Re: Synology DS211+ Can´t switch to "keep original"
boko wrote:Hello from Darmstadt Germany.
~$ ffmpeg
Any idea?
Thanks boko
are you using the standard serviio console or the third party webui ??
boko
Post Fri Mar 25, 2011 7:16 pm
Since it´s a headless NAS, I´m using the AcidumIrae’s PHP web UI for Serviio.
Post Fri Mar 25, 2011 7:39 pm
Then you should ask him on the appropriate topic. Btw you can use the console in remote mode (see FAQ) with your headless server.
Post Fri Mar 25, 2011 7:53 pm
boko wrote:Since it´s a headless NAS, I´m using the AcidumIrae’s PHP web UI for Serviio.
Is it really i didnt now that :roll: so clearly you missed the part of that forum that say THIRD PARTY meaning it not made by serviio dev so asking for support wont get you very far unless u ask in the same section as that THIRD PARTY ui.
boko
Post Fri Mar 25, 2011 8:30 pm
Sorry, but I wasn´t sure were to start.
I just tryed to install serviio-console on my windows pc. Where do I find the system-variable to address my serviio-server?
Post Fri Mar 25, 2011 8:32 pm
boko wrote:Sorry, but I wasn´t sure were to start.
click the FAQ link in my signiture mate all the information is there :)
boko
Post Sun Mar 27, 2011 9:07 pm
OK, finaly it´s working now with the console in remote mode.
I installed serviio console on my WIN 7 and added this to "ServiioConsole.exe.vmoptions":
-Dserviio.remoteHost=192.168.2.74
The same I had to add on the NAS in "serviio.sh" at the end off JAVA_OPTS.
Sorry for asking silly questions, but I just had a bit SUN-Solaris knowledge 20 years ago.
Best regards,
boko
Post Sun Mar 27, 2011 10:21 pm
boko wrote:OK, finaly it´s working now with the console in remote mode.
Best regards,
boko
no such thing as a stupid question, you cant learn if you dont ask questions :)
dudewithasonynx710
Post Tue Apr 05, 2011 7:12 am
I'm seroiusly having troubles with my installation too...Kept me up half the night and still not working!
But what did I expect! I'm totally newbie and It took me one hour to just figure out how to login through Shell terminal :oops:
Well, tonight I'll give it another try.. then I'll start shooting out questions :-)
BTW: is there some way to restart/rewind installation of ipkg/FFmpeg.. It all got messed up somewhere in the middle.. maybe I skipped/missed a couple of steps :| Or do I even need to "uninstall" ?
Post Tue Apr 05, 2011 9:41 am
dudewithasonynx710 wrote:I'm seroiusly having troubles with my installation too...Kept me up half the night and still not working!
thats a whole different question there please start a new topic rather than hijacking an old one..
i will request this topic to be split for you this time though :)
boko
Post Tue Apr 05, 2011 11:29 am
to uninstall everything, you may do this:
cd /
umount /opt
rm -R /volume1/opt
rm -R /opt
reboot
rm -rf /volume1/@optware
rm -rf /usr/lib/ipkg
During my learning phase, I had to do it several times with no problems.
Best, boko
Users browsing this forum: Bing [Bot] and 19 guests
