ffmpeg transcode AAC error
nkodak
Post Wed Sep 11, 2019 5:36 pm
I'm getting an error in my MediaBrowser logs about a transcoding error, referencing AAC and the way it's attempting to work. This only happens with some movies and not others.
2019-09-11 12:54:23,128 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
[aac @ 0x13e3380] The encoder 'aac' is experimental but experimental codecs are not enabled, add '-strict -2' if you want to use it.
[aac @ 0x13e3380] Alternatively use the non experimental encoder 'libfdk_aac'.
2019-09-11 12:55:22,895 WARN  [ServiioStatusService] IOException occurred. Returning error code 500 to the REST layer. Message: Transcoded file '/serviio-tmp/Serviio/transcoding-temp-8002d1ec14631089cf68d45e5b9b0aad.stf/playlist.m3u8' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/serviio-tmp/Serviio/transcoding-temp-8002d1ec14631089cf68d45e5b9b0aad.stf/playlist.m3u8' cannot be found, FFmpeg execution probably failed
Any assistance would be appreciated.
Serviio 2.0 | CentOS v7
Serviio 2.4 Pro on CentOS 9 | Roku 4K Streaming Stick | Onn Roku TV | HD & 4K TV's
Post Wed Sep 18, 2019 9:08 pm
Re: ffmpeg transcode AAC error
this looks like an old version of ffmpeg. You will need to compile your own new version or get one from a repo. Currently using 3.2.4
nkodak
Post Thu Oct 31, 2019 4:02 pm
Hey zip... I am still trying figure out this FFMPEG issue, but I noticed that the 2.0 download page says that FFMPEG is actually included in v2.0. I've removed the installed RPM I had for FFMPEG, but now Serviio says it can't find it at all. Please advise.
cmakula
Post Thu Oct 31, 2019 4:19 pm
zip, correct me if I am wrong.
I believe the Windows and Mac versions include ffmpeg in v2.0. The Linux versions do not, because they can be obtained from your distribution (RPM, YUM, APT, etc.), or compiled from ffmpeg.org.
:ugeek:
Serviio Server - Dell PowerEdge R420, Dual Xeon E5-2420, 4x120 GB SSD RAID 0, 64 GB RAM (Serviio running from RAMdisk), 4 NICs (aggregated to LAN), 10Gbe to NAS, Ubuntu Server 24.04.3
NFS File Server - Synology DS1517+, 20TB disk space (5x4TB), 4 NICs (aggregated to LAN), 10Gbe to Serviio Server
nkodak
Post Thu Oct 31, 2019 4:37 pm
I don't like that you're right.. I love linux, and for stuff like this, it's always so frustrating. Attempting to compile FFMPEG now...
cmakula
Post Thu Oct 31, 2019 5:21 pm
nkodak wrote:I don't like that you're right.. I love linux, and for stuff like this, it's always so frustrating. Attempting to compile FFMPEG now...
You're brave. I would just use yum. CentOS is good like that...
On the bright side, with CentOS, once you have it up and running, you probably can just leave it alone (occasionally update and reboot), and it will continue to work just fine 2 years from now...
:ugeek:
Users browsing this forum: Google [Bot] and 49 guests
