Subtitles doesnt show correctly
easyedwin
Post Tue Apr 05, 2011 1:07 pm
I love this program, but i have a little program.
On some srt files i have wordss like: oké.
But when i play the file it shows like: oké
How can this happen? How can i solve it?
Post Tue Apr 05, 2011 1:31 pm
Re: Subtitles doesnt show correctly
that mean the SRT was not stored in correct format (UTF-8) or you have the wrong language set in teh subtitles menu on your samsung :)
easyedwin
Post Tue Apr 05, 2011 1:41 pm
Cerberus wrote:that mean the SRT was not stored in correct format (UTF-8) or you have the wrong language set in teh subtitles menu on your samsung :)
Hmm.. subtitles on samsung menu: West Eurupe.. Thats where i am:p
How can i be sure that it is stored in utf-8?
Post Tue Apr 05, 2011 2:38 pm
check the file properties and attach it here and i will take a look at it for ya :)
easyedwin
Post Tue Apr 05, 2011 2:50 pm
Dont know what you mean, but i will attach the srt file.
m-kllspd1080.zip
subtitles
(28.9 KiB) Downloaded 747 times
Post Tue Apr 05, 2011 2:55 pm
you may be in West Europe but the file is probably encoded using a different code page. You have to select encoding of the file, not depending where you are.
Post Tue Apr 05, 2011 3:08 pm
here try this :)
m-kllspd1080.zip
(30.03 KiB) Downloaded 799 times
easyedwin
Post Tue Apr 05, 2011 4:04 pm
Cerberus wrote:here try this :)
m-kllspd1080.zip
still got the same problem :(
Post Tue Apr 05, 2011 4:15 pm
m-kllspd1080.zip
dunno then sorry its encoded correctly all i can think is play with the subtitle reigon on the device.
easyedwin
Post Tue Apr 05, 2011 6:40 pm
is it possible to use the mkv's subtitle instead of .srt extern file?
Post Tue Apr 05, 2011 6:57 pm
easyedwin wrote:is it possible to use the mkv's subtitle instead of .srt extern file?
not currently no..
